D7 pinion latch adjustment
jonstark
Send a private message to jonstark
Is the 2", internally wrenched, plug just forward of the pinion arm into the "bell housing" where I can access the fly weight adjustment for the pinion latch?
thanks,
jon
1981 D3B, 1955 D7 3T, 1954 Ford Jubilee, 2001 Kubota L3010
Fri, Oct 26, 2012 5:44 AM
Thank you received: 46
Good the hear your up and running again!!!!......yes on the plug access for starter pinion latch adjustment.
Fri, Oct 26, 2012 6:33 AM
Thank you received: 32
Hi jonstark,
yes, that is the acess hole for the adjustment.
Scan below is from the SRB.
Hope this helps,
Fri, Oct 26, 2012 6:36 AM
jonstark
Reply to edb:
Hi jonstark,
Hope this helps,
Thanks for the info Eddie!
Not looking forward to working in that little hole. At least it's still above freezing here (for a little while longer). I hope the spring is intact.
Did I ever move some dirt today! Gotta post pix soon. I love my D7!!! Poor little old D3B has been relegated to road repairs. Better give her some exercise before winter storage.
jon
Fri, Oct 26, 2012 7:37 AM
