D7 painted with Axalta Industrial IMRON HIWAY Yellow
Showing 1 to 9 of 9 results
17AFarmer
 [attachment=69683]F13F92C6-2942-4006-B431-37079BC6C1ED.jpeg[/attachment]
Fri, Nov 25, 2022 9:49 AM
D4Jim
Thank you received: 10
Nice looking tractor!!
Cats Forever
Fri, Nov 25, 2022 11:31 AM
Mschwartz
Reply to D4Jim:
Looks almost to nice to use
Fri, Nov 25, 2022 1:09 PM
gary in CA
Reply to Mschwartz:
It's a runner
https://www.youtube.com/watch?v=Q_P0lM73WBE
Fri, Nov 25, 2022 10:07 PM
Thank you received: 68
Reply to gary in CA:
It's a runner
Very nice 17A. What brand of hydraulic unit on the rear? Safe-T-Cab, SWECO, HCL Liv Power or ??? Several similarities in them because of the tank shape.
Fri, Nov 25, 2022 11:42 PM
gary in CA
JM I believe it's a BEE GEE. We had one just like it on our D7E.Maybe Mike will tell more
https://www.youtube.com/shorts/2h2C0bJCzZY
Fri, Nov 25, 2022 11:51 PM
Thanks Gary. Maybe someone just did a tank swap. From the side view it does still look like 2 spool Be-Ge, some did nice change overs to high pressure as well.
I need to sort my pump pile here. I have been taking junk units and converting to 2 valve etc. with spare parts. Mixing and matching!
BTW, that is supposed to be the same paint the trailer guys used to paint one of my #40 scrapers with. Supposed to last a long time and no fading. JM
Sat, Nov 26, 2022 12:12 AM
Thank you received: 30
2 pack is hard wearing, has good very good chemical and fuel resistance and does hold its gloss well but it requires more expensive equipment to apply and inst a suitable for backyard use due to the very toxic compounds in the catalyst. they do have 2 pack paints that dont contain the isocyanate which are safer but that is still nasty stuff.
Sat, Nov 26, 2022 5:12 AM
17AFarmer
Reply to trainzkid88:
The pump is a BeGe PR220 if I remember right I put it on in about 1985., As far as painting 2 part IMRON as long as you use a good respirator and gloves i Is safe enough, as far as paint guns all I use is. Harbor Freight guns use their mid grade guns which I think are a little over a. $100.00 now, As far as a place to paint I have painted in a shop, out the open, and in a grain elevator shed , it doesn’t make any difference to me as long as I can see what I am doing without a lot of shadows! That D7 was painted right where it’s setting in that picture. If I can do it ANYBODY can do it. 17afarmer. Mike
Sat, Nov 26, 2022 8:58 AM
Reply to 17AFarmer:
the problem with isocyanate is your well and truly over exposed to it before you feel affected. hence why it needs supplied air or PAPR type respirators which have monitoring on the filters so you know when to change them. there is no way to tell visually or by weight if the chemical filter is worn out. these are 3 times the price of normal non pressurised respirators. and supplied air requires special filters to protect you from oil mist and chemical pneumonia.
yes working outside on the farm your probably okay as no one is close by. and fresh air with a light breeze helps keep the fumes at bay.
Sat, Nov 26, 2022 5:26 PM
Newby Hall Tractor Fest
