D7 front CCU leaking oil
Showing 1 to 10 of 15 results
funflyer26
Send a private message to funflyer26
I have recently acquired a 1953 D7 (D7-7M1629SP) and after the first day of using it, the front gear box running the cable drum started leaking oil which got the pads oily and now it doesn't have the friction to hold the blade up. I obviously need to pull it apart fix the seal, clean the pads and then it should work again but I have hit a roadblock in the disassembly process. I have the operation and maintenance instructions, the servicemen's reference book, and the parts book but they are all for the base tractor itself, nothing for the attachment. I have attached some pictures, including what I think is the serial number on the gear box, does anyone know the next step to taking this thing apart? Thanks!
Mon, Dec 12, 2011 11:28 AM
u-joint
Send a private message to u-joint
you will need to acquire a cable control manual. it should be on a tag if there is one left. my guess is its a number 24.
Mon, Dec 12, 2011 1:24 PM
Old 3T lover
Reply to u-joint:
It has been well over 30+ years since I did this so I may be wrong... but here goes anyway. With the cover off, just release the brake band and UNadjust the CCU drum(unscrew the adjustment of cable spool/drum) until you can remove it. All the seals and how to continue the disassembly will be revealed then.
Mon, Dec 12, 2011 7:38 PM
funflyer26
Reply to Old 3T lover:
That should get me started, thanks!
Mon, Dec 12, 2011 8:22 PM
Thank you received: 46
Reply to funflyer26:
The #24 manual recommends separating the cable drum from the brake drum as next step (unscrew the adjusting sleeve until you can lift it off). Can be removed as an assembly but your going to have to separate to access the seal on the back of the cable drum anyway.
Service manual for the #27, 25, 24, 23 and 21 Cable Controls is Form #10088
Mon, Dec 12, 2011 10:28 PM
Kelly
[quote="Old Magnet"]The #24 manual recommends separating the cable drum from the brake drum as next step (unscrew the adjusting sleeve until you can lift it off). Can be removed as an assembly but your going to have to separate to access the seal on the back of the cable drum anyway.
Service manual for the #27, 25, 24, 23 and 21 Cable Controls is Form #10088[/quote]
I’ll add a little more to what the boys are talking about. One important item is getting the bearing adjusted when you reassembly your unit. Hope this helps.
Kelly
[attachment=11504]24_cabledrumremoval_1.pdf[/attachment][attachment=11503]24_cabledrumremoval_2..pdf[/attachment]
Tue, Dec 13, 2011 4:14 AM
bjohnson
Send a private message to bjohnson
Look on ebay we found one at a good price.
Wed, Dec 14, 2011 7:48 AM
funflyer26
Reply to bjohnson:
Thank you all for your help, once I finally got time to go out there in the daylight the outer drum came off easily. However, now i'm stuck on the inner drum. According to the service manual once the capscrews are taken off and the plate is twisted and removed the inner drum should slide right off the shaft. but mine is froze solid, is that just a matter of time holding it in place? I've put some pretty good force on it but it hasn't budged. Am i missing something that the book isn't saying? The picture attached shows where its at now.
Sun, Dec 25, 2011 2:50 AM
Thank you received: 31
Hi funflyer26,
you should be able to remove the bolts behind the pressure plate by inserting a suitable socket wrench thru one of the holes in the pressure plate. I believe I can see a bolt head at about 12 o'clock in your pic in post #8. Once all these bolts are removed you should be able to withdraw the assembly.
You really need the Service Book to do these as there are some fine shim adjustments to do to set it up correctly not to mention resetting the screw and lever into position to work full range.
Maybe Kelly would be kind enough to post up the assembly steps from his SRB.
Merry Christmas to One and All.
Sun, Dec 25, 2011 5:27 AM
razz
Send a private message to razz
Reply to edb:
Hi funflyer26,
funflyer if you need a brake band or clucth disc i have some that are in real good condition. I am in NC Iowa. Razz. They are for a 24 unit.
Sun, Dec 25, 2011 9:21 AM
funflyer26
Reply to razz:
I saw those bolts, but it looked like it removed something behind the pressure plate. I'll take those out next, thanks. I've got a copy of the service manual, it is the reason I've gotten so far.
And I'm hoping to be able to clean up the brake band without replacing it, but if it stays too oily then i'll be in touch for sure, thanks!
Mon, Dec 26, 2011 1:36 AM
