D7 E transmission oil change
Showing 1 to 7 of 7 results
23 KV
Send a private message to 23 KV
Hi guys,
Can someone please help me. I want to do an oil change on my 1966 D7 , AND NOT SCREW UP.
I found the 3 pipe plugs in the back housing.
Do I need to drop the belly pan and drain a pipe ?
I know why it's very important to have books, but I can't find any originals yet. If anyone has a set for sale please let me know.
Thanks for any help !
Dave
Sat, May 28, 2016 2:56 AM
Thank you received: 19
Depends on the tractor s/n. For 1966 units 48A5951 to 7500 the break between having to access the suction screen on the left front of the transmission (belly pan removal required) vs the later type remote screen occurred at 48A6393. Also could depend on what transmission you have.
Sat, May 28, 2016 3:50 AM
sdmuleman
Send a private message to sdmuleman
I have a pdf of the service manual for a 47A/48A D7. PM me your email address and I'll send it to you.
Sat, May 28, 2016 3:58 AM
23 KV
Reply to sdmuleman:
Old Magnet,
The sn. is , 7E2073 and that's military.
It has been interchanged by fine folks here as, D7 E 48A 6883 ~ up
Dave
Sat, May 28, 2016 5:45 AM
Reply to 23 KV:
Old Magnet,
Dave
I did miss a digit but for your s/n you don't need to mess with removing a line to get access to the screen/s.
Sat, May 28, 2016 6:32 AM
23 KV
O M,
Many thanks ! I'm on it . 😊
Dave
Sat, May 28, 2016 7:42 AM
23 KV
Reply to 23 KV:
O M,
Dave
Morning guys,
I'm still doing an oil and filter change for a D7 E transmission.
I found all 4 drain plugs,
The 5 bolt cover w/ wire mesh strainer behind it,
The filter at pump on right side by the motor,
The two filters at left of seat,
BUT, I can't find a magnetic strainer/filter, ....... I have noticed this talked about in a few threads.
This is an old military D7, I have a parts book, but that's all. SN. at draw-bar reads 75E2073 converts to D7 E 48A 6883 and up .
Dave :usa2:
Mon, May 30, 2016 7:45 PM
Reply to 23 KV:
Morning guys,
Dave :usa2:
As you move up the s/n's the magnetic filter screen assembly went away.
The five bolt cover is on the scavenge pump suction screen. It is wrongly called out as using 10 bolts in the late s/n parts book.
Edit: Sorry, got on the wrong page.
The Magnetic/screen filter was carried through to the end.
Item #19. I don't see how you could miss it.
Tue, May 31, 2016 7:18 AM
