D7 Cable Blade Won't Raise
catdude
Send a private message to catdude
lOOKING AT A D7 17A CABLE DOZER THAT IS FOR SALE. SELLER SAYS EVERYTHING WORKS GOOD EXCEPT THE BLADE WON'T RAISE. IT DID WORK FINE AT LAST USE, POSSIBLY A YEAR AGO. ANY IDEAS ON WHAT TO CHECK? THANKS!
Fri, Apr 9, 2010 9:17 AM
Cable broken
Clutches out of adjustment
PTO shaft disconnected from the front of the engine, or main clutch disengaged on the rear mount type
Splines on the pto shaft or Gears in the CCU stripped.
Does it have front mount or rear mount CCU?
NEVER adjust a CCU with the engine running on the front mount CCU driven off the engine front pulley or with the main clutch engaged on the rear mount CCU driven off the transmission shaft. Just too many bad things that can happen if you leave the power to it while you adjust it.
Fri, Apr 9, 2010 10:14 AM
D4Doug
Send a private message to D4Doug
Cable broken
Just in case you don't know what a CCU is it's a cable control unit. Good luck
Fri, Apr 9, 2010 10:29 AM
catsilver
Reply to D4Doug:
I would go further than that and say don't fiddle with anything on a CCU with the engine running at all, the main clutch could warm up and grab or the pilot bearing sieze (the old ones are only grease lubed) and set the CCU in motion. Work through and understand its operation while 'dead' and sort any stiff linkage etc before making any adjustments.
Fri, Apr 9, 2010 10:24 PM
