D7 and a half
D7 and a half
Showing 1 to 7 of 7 results
fordhook
Send a private message to fordhook
Lloyd Ranch[attachment=20893]Pics 149.jpg[/attachment][attachment=20894]New Pictures 115.jpg[/attachment][attachment=20895]New Pictures 114.jpg[/attachment][attachment=20896]New Pictures 113.jpg[/attachment][attachment=20897]New Pictures 049.jpg[/attachment][attachment=20898]2006 Farm and Family 027.jpg[/attachment][attachment=20899]Lloyd Ranch D7 and a half 03 small.jpg[/attachment][attachment=20900]Pics 161.jpg[/attachment]
Wed, Dec 18, 2013 10:37 PM
fordhook
[attachment=20901]D7 and a half JPEG small.jpg[/attachment][attachment=20902]Lloyd Ranch D7 and a half 02 small.jpg[/attachment]Lloyd Ranch
Wed, Dec 18, 2013 11:21 PM
83Jim
Send a private message to 83Jim
Reply to fordhook:
This must be Dick's D7E repowered with a D342 engine. Looks like a really well done fabrication.
Man, I would love to hear it running.
When I read the original post describing this change over, my initial thoughts were that the tranny might not live long. This was based on info Ozdozer had posted some time ago describing how the D7F had a 3306 engine but used the D7E transmission. The early versions had a lot of problems until a D6C tranny was substituted along with changing the final drive gearing. But that was the power shift version and maybe the direct drive will do better.
At any rate, did I mention that I would love to hear this hydrid running? hint hint
You only need two tools in life - WD-40 and Duct tape. If it doesn't move and should, use the WD-40 If it shouldn't move and does, use the duct tape.
Cat D4D 83J w 3304 PC engine, FOPS, s/t blade, D4F winch, air ride seat, "wobble" stick blade lever and D8H control panel
Cat 920 62K w 3304 PC engine, FOPS, 4 in 1 bucket
1995 Dodge Ram 2500 4x4 RCSB Cummins 5 speed
Thu, Dec 19, 2013 2:18 AM
Thank you received: 93
Reply to 83Jim:
that is a really neat conversion.
I really like the extended fenders.
The early D7F's, fitted with the old D7E trans's, failed mainly because of the old big planetaries not being able to cope with the extra approximate 1000 engine rpm's of the D333T engine. The trans transfer gears were another weak point.
As was stated above, Cat soon came up with a beefed up D6 trans that fixed all the problems and performed as well as it had in the D6. I was running the Trans Shop at The Dealer when all this came about.
Thu, Dec 19, 2013 6:09 AM
Bruce P
Thank you received: 38
Reply to edb:
That D7E with the propane tank on the front is one slick kitty as well. Dick rigged up a propane sniffer for those tough spots. It is still a 4 cylinder. Thanks for posting the pics.
Bruce P
Thu, Dec 19, 2013 9:17 AM
Reply to Bruce P:
Bruce P
Did the late 7E's have about the same transmission as the 8H's?
Thu, Dec 19, 2013 9:56 AM
d4e
Send a private message to d4e
Nice Cat, I see its got a Spokane rock guard on it
Thu, Dec 19, 2013 10:32 AM
Reply to d4e:
Hi ROME/KG,
no, the D8H was a lesser version of the D9 Trans, ie, less plates in some clutches and different transfer gearing.
The D7F was an upgraded, extra plates in some clutches, D6C/D/977 Trans. with the necessary transfer gearing and housing to adapt it to the larger transmission aperture on the main frame of the D7F.
Thu, Dec 19, 2013 10:56 AM
