D7 5M6374 Magneto WICO or Bosch?
Showing 1 to 7 of 7 results
jrpmccoy
Send a private message to jrpmccoy
Anyone have the cross reference from Caterpillar to WICO?   I have one but it doesn't have the 5M6374 listed in it which has me wondering.
Thanks!
Tue, May 28, 2024 10:55 PM
gemdozer
Thank you received: 25
The 5m6374 magneto fitt on 17a serie 11660 to 14669 and fitt on d8 h and have a have a ground connection under
Wed, May 29, 2024 12:26 AM
jrpmccoy
Reply to gemdozer:
Yes this does but I need the WICO number to order parts, if it even is a WICO?
Wed, May 29, 2024 1:17 AM
Thank you received: 63
Reply to jrpmccoy:
5M6374 can be a Wico XH2541, XH2541C, XH2733 or XH2733. Odd Fire
Wed, May 29, 2024 2:33 AM
jrpmccoy
Thanks Old Magnet! This is SN 17A13356 so I don't think it's an odd fire but that brings up a question, What was the last year of the odd fire pony motor?
Wed, May 29, 2024 2:44 AM
Reply to jrpmccoy:
17A1 to 17A11667 are even fire.
Wed, May 29, 2024 5:27 AM
jrpmccoy
So they went back to Odd Fire vs even fire. Great info and thanks for correcting me. I found this interesting info "The odd fire mg should have two sparkplug terminals together on one side of the cap 90 degrees apart while the even fire pony has them on opposite sides of the cap 180 degrees from each other. " Of course this assumes original magneto is still in place. Looking to make smoke this Friday. I have the magneto rebuilt and throwing a good spark, I have a carb off of my 1959 D7 17A which runs, got the valves free on the newer D7 pony so it should just be timing. Still a bit worried about potential water in the diesel fuel but thinking the filters will trap it.
Wed, May 29, 2024 9:13 AM
Reply to jrpmccoy:
The even fire pony had the vertical magneto. Also associated with the shared pony/main engine lube system which also went away.
Wed, May 29, 2024 9:31 AM
