D7 - 4T cylinder projection
pmduke
Send a private message to pmduke
I am after the liner projection specifications for the D7 engine - 4T prefix.
Also does anybody have the run in procedure for the engine.
Thu, Jul 15, 2010 4:12 PM
Thank you received: 19
Liner projection should be 0.002 to 0.005 in. with a maximum difference between liner projection of 0.002 in.
There are no special run in requirements but the 4T manual does state that you should operate at light loads for the first 64 hours on a new tractor.
Avoid long periods of idling.
Good luck with your start up.
Thu, Jul 15, 2010 9:45 PM
pmduke
Thank you very much for the reply, really appreciated.
Fri, Jul 16, 2010 6:41 AM
Earlcoate Charity Open Day
