Need some advice please.
Went to start the tractor a few weeks ago and could not get the pony motor started. Determined it had no spark. Removed the mag and sent it off to be rebuilt. Took me several hours to get all the timing aspects correct and got the pony to fire off and run last night about dark. Thought I was home free and shut everything down for the night. Got up early this morning and the pony fired right up. Went to start turning the main engine and the starting clutch started slipping. Pulled the cover plate to adjust it and found out quickly that it was at the end of the adjustment and would not tighten further. Also found quite a bit of oil in the clutch housing.
Appears to have come through from the pony motor. In reading the manual I learned that in order to work on the clutch I need to remove the entire pony motor, clutch, and starting transmission. My questions are:
1) Is there any way to replace the starting clutch without removing the pony motor?
2) If the answer to 1 is no can anyone recommend a mechanic in the Albany, Georgia area? I lack the lifting capability on this size and weight.
If I get the pony removed then the choice of repairing or changing to direct electric start comes into play.
Any and all thoughts or suggestions are welcome.
Thanks,
Robert(goldminer7759)
