D7 3T radiator neck
D7 3T radiator neck
Albertagary
Send a private message to Albertagary
Hello Guy's;
I have a D7 3T that has a damaged radiator neck.Rad cap doesn't fit good.Do they make replacement slip over necks to repair?I know they make some for Old JD Tractors.Thanks
Sun, Apr 12, 2020 10:13 AM
Thank you received: 22
I know the one for the D2 is listed as a separate part number - check your parts catalog to see if it is for your D7 serial # then try Cat, machinerytrader, and Florin. Mine is dented and comes out but I'm in no hurry to deal with it as the cap can be fitted / removed and it doesn't otherwise give problems. I haven't run it under rated power though, or for any appreciable length of time so it might become an issue for me.
Sun, Apr 12, 2020 10:21 PM
JackD6-5R
I used a Fernco coupler that has a reducer to get to a smaller size and put cap on it. I got rubber fernco coupler at tractor supply store. It also got water level a little higher in rad, to keep water up in head if working downhill. Not sure about spelling of coupler brand.
Mon, Apr 13, 2020 12:03 AM
Reply to JackD6-5R:
3T's up to s/n 19335 had separate neck 4F6386
Mon, Apr 13, 2020 1:44 AM
Andrew
Does your machine have a brass radiator top tank or is it the later tractor with cast tanks??
Mon, Apr 13, 2020 3:10 AM
Albertagary
Reply to Andrew:
My 3T has a brass neck. thanks for all the help.
Mon, Apr 13, 2020 11:04 AM
