Welcome to ACMOC, Good luck with your D7 3T and parts. It would be a big help if you would add your location to your profile(at least your general location). This would affect equipment values also.
hello again, the location is down east Maine. no one to venture a guess on values. i was thinking $3500 on D7 and $500 on pony and $2000 on winch????
Without knowing the actual condition its pretty hard to estimate.
I don't think your unreasonable with your asking but actuals may be about 1/2 those numbers.
as for condition its really not bad I try to get some action shots of it but im 400 miles away now, it doesnt look nice only because of paint but its the only crawler i have had that the tracks are good it leaks nothing the brakes and clutches all work great it has great oil pressure although the blade is welded up and the cylinders are pitted some but do not leak .I was told its a 1944 and it does have the early hood that extends over the radiator I think Ill knock down the spare pony motor to around 300.00 thanks Dan
My files show it to be a late 1945 machine.
