D7-3T Needs a little work
Showing 1 to 7 of 7 results
Ifonly
Send a private message to Ifonly
Here is an old girl that needs a little tlc. It has sat for quite a few years but hopefully we will have her going under her own power this summer. Main turns over but the pony is stuck. It's had more than it's share of hard times and little maintenance but I guess it's not the first. The undercarriage doesn't look to bad other than sprockets and missing shields. The blade is getting a little thin to.
Thu, Mar 18, 2010 9:50 AM
Billy D7 4T
Send a private message to Billy D7 4T
Nice ole 3T, I am really interested as to what the attachment is, the steel frame with the sheave blocks, on the back end near the LeTourneau R7 PCU ?
I've never seen one of these, looks like something that you can use the spare reel on the R7 for, maybe yarding logs or something ? Though these PCU's have high line speeds, unlike a regular winch, I've often wondered if they would work like that under the right conditions.
Sun, Mar 21, 2010 11:06 PM
terrywelch_archive
Reply to Billy D7 4T:
Ifonly, you should have been there when I rode it off the lowboy. The machine has not run in about 20 years. No photos of the disk that came with it? That was a bigger job unloading it than the D-7. Once the 7 started rolling it was ride it down until it stopped. We used a Farmall M and a skid steer to help get it going off the trailer. The steering clutches and brakes need work as it will not release the clutchs and there is no brakes.
Terry
Sun, Mar 21, 2010 11:33 PM
terrywelch_archive
Reply to terrywelch_archive:
Terry
Sorry, I do see the disc in the backround of one of the the photos. Maybe you maight want to come out when we have a work day on April 10th to get the other machines oiled up and ready for spring and June. We might even get the 7 moved if it is dry enough. It can not stay there after it drys up. So if you like stop by on the 10 and lend a hand if you can. We might even have a drag line show up then or maybe two. Tell Pete he can come down and supervise as we will be working on his D-8 also.
Terry
Sun, Mar 21, 2010 11:42 PM
terrywelch_archive
Terry
Here is a little history on this machine. It was owned by a company out of Madison WI and was bought by a gentleman and moved to Hatfield WI. It was used there until a flood hit and washed it down a hill into or near a gravel pit that it ended up in. Where it has sat for about 20 years. The owner had it moved to our show grounds a few weeks ago. We also have a 2U D8 that he owns that is restored. Both these machines came from the same company in Madison before the current owner bought them. The machine has a mounted disk that was taken off to move it. The disk hooks to the frame on the rear. You can see it in the one photo setting a ways behind the machine. He also has a pan for it.
Sun, Mar 21, 2010 11:54 PM
Ifonly
Hers a couple pix of the pan that tw spoke of.
Mon, Mar 22, 2010 6:12 AM
Ifonly
Reply to Ifonly:
And the Rome Plow disc
Tue, Mar 23, 2010 11:28 PM
Rd6 plower
Send a private message to Rd6 plower
Reply to Ifonly:
The scraper is a Letourneau Model LP, we have one and pull it with our 1H D8 but a 3T will chug right a long!😄
Tue, Mar 23, 2010 11:57 PM
