D7 3t Idler Collar
D7 3t Idler Collar
V14
Send a private message to V14
The idler collar on the left side was cracked when i bought it and needs replaced [1F8280]. I can find the collar and seals needed easily but I'm trying to figure out what will go into this project.
If I look at the parts book it appears that I can just remove the stuff on the exterior side of the idler and throw on the new items, but it sounds too simple. Can anyone confirm that is accurate, or am I looking and taking tracks off and removing the idler completely to swap that collar. Pic from part book attached for reference. The servicemens nor the operators book has any details I could find on replacing just that part, only the idler itself.
Thu, Jul 20, 2023 12:19 AM
gemdozer
Thank you received: 25
You need to separated the track to get the collar
Thu, Jul 20, 2023 1:06 AM
V14
Reply to gemdozer:
That's what I was afraid of. Thanks for letting me know. A follow up question, how important is that collar assembly for undercarriage longevity? I may have understated the damage it isn't cracked it's split at the top. I figure it's pretty important and worth the hassle of splitting the tracks.
Thu, Jul 20, 2023 1:16 AM
gemdozer
Reply to V14:
The collar keep running the idler straight in the track
Thu, Jul 20, 2023 7:55 AM
