D7-3T brake band help
lbrooks
Send a private message to lbrooks
I have a question on removing the brake band on the D7-3T. I am going to replace brake liners, I need to remove brake bands, is thier a trick to removing the the pin that holds it or do I have to remove the whole anchor plate to get it off?? I got the band loose. How does it come out?? Do I have to remove fuel tank or do i split the band apart?? Help How??
Fri, May 17, 2013 11:11 PM
Old 3T lover
I used to lean the tank forward and tie it off to the air cleaner. Then remove the large top plate, disconnect linkage, remove pins and then rotate band until I was able to remove bolts that held the band together, remove that section and then rotate the other direction and remove the remaining bolts that held the last 2 sections together. You reinstall in the same way.....reverse order.
Sat, May 18, 2013 2:25 AM
lbrooks
Reply to Old 3T lover:
Thanks Ol 3T Lover , i got it it worked fine that way. Now to figure out how to rivet new brake lining on!!
Sat, May 18, 2013 2:52 AM
Old 3T lover
Reply to lbrooks:
Use an old time rivet machine......probably can't find one handy or close by these days.
Put a rod about the size of the head of the rivet in the vise, place rivet over rod, use a very blunt punch to start the spreading of the rivet on the other side, use a bolt to complete the bradding, ....just don't over do the bradding/flattening of the rivet.
You may find having 4 hands is very helpful.
Sat, May 18, 2013 3:46 AM
