D7 3T 4T Pistons
D7 3T 4T Pistons
D74T
Send a private message to D74T
Does anybody know if part number 3F7577 interchanges with 1H5888? I notice that the piston body on the 1H5888 is shorter than the 3F7577 by 1 inch. pin height is the same.
Cheers!
Thu, Nov 9, 2023 7:28 AM
josh
Thank you received: 14
No, but it does cross with 1H5889, recheck your number. It also crosses with 7B490, 7B5750 and 1F3043, also 1H5888 does not come up at all in my book.
Thu, Nov 9, 2023 7:51 AM
D74T
Reply to josh:
Hi Josh, thanks for your quick response.
I found that 1h5889 interchanges with 3F7577 according to tractorparts.com website.
Does this mean it would be ok to use?
Cheers.
Enrico
Thu, Nov 9, 2023 8:17 AM
josh
Reply to D74T:
Cheers.
Enrico
Yes, that is what is implied when the numbers cross, usually the higher number is just the (at the time) current replacement for the part.
Thu, Nov 9, 2023 8:23 AM
D74T
Reply to josh:
Thanks for you input, much appreciated.
Thu, Nov 9, 2023 8:49 AM
