D7 3t 1950 Pony clutch problem
7mileranch
Send a private message to 7mileranch
Fixed the mag on the pony motor. Replaced oils in the motor, hi lo trans, and hand crank. Pony fired up fairly easy. Problem is the clutch doesn't seem to be working properly. I have to idle the pony right down, and pull the pinion in. The pinion grinds a little when this happens. I also have to hold the pinion lever in while starting the main engine. My understanding is the pinion lever should pop in and stay until the main fires up and then it kicks out. The clutch lever only moves a couple inches each way if that helps.
Fri, Apr 22, 2016 7:33 AM
Andrew
3T will have a dry clutch with a clutch brake activated when the clutch lever is pushed towards the engine.
The clutch lever will be the bottom one.
Push the bottom lever towards the engine and wait for the pinion to stop spinning before engaging the top pinion lever. Yes the pinion should stay locked in.
Sat, Apr 23, 2016 3:27 AM
Thank you received: 93
Reply to Andrew:
Hi,
Toby has kindly made these great tutorials on the pony pinion operation and repair.
Hope they help.
https://www.youtube.com/watch?v=OiUL4UkERls
https://www.youtube.com/watch?v=lKI3wTZU4AA
Sat, Apr 23, 2016 8:07 AM
7mileranch
Reply to edb:
Hi,
Hope they help.
Thanks, was away this weekend will try it.
Tue, Apr 26, 2016 11:09 AM
