D7 3 T oil clutch brake
Showing 1 to 10 of 11 results
DManring
Send a private message to DManring
I'm working on a D7 3t that clutch brake seems not working. I am not at the tractor till week of 26 Aug. 2024.Im looking at parts book and see the assembly. What i need to know from the experienced hands is it the lining on the shoe in most cases? I'm Shure adjustment is needed. I'm trying to see what parts can be found and maybe purchased ahead of time. I failed to inspect before i left the machine a few weeks ago. Thanks for the vast knowledge on this page!
Mon, Aug 19, 2024 10:09 PM
seiscat
The ACMOC library contains all of manuals for the D7 3T. The operations and maintenance instructions(OMI) has the clutch, transmission brake instructions and more. I have a OMI for sale cheap if you are interested send me a PM.
Craig (seiscat)
Mon, Aug 19, 2024 11:17 PM
DManring
Reply to seiscat:
Craig (seiscat)
Thank you, I have all the publications . My question was directed to a hand ‘si on persons comments on actually doing the repairs
Tue, Aug 27, 2024 8:28 PM
Thank you received: 62
Reply to DManring:
Have not done any work on a D7, so a wild question. But I know Cat used many of the same type pieces on a 3t D7 as the D6 9u's back end. So if the brake drum is external to the clutch as 9u oil clutch is it can be ether or, or both brake lining and the drum that has the wear. It would seem the brake lining changed over time, and latter kinds were harder and wore the drum more.
Tue, Aug 27, 2024 10:09 PM
seiscat
Reply to DManring:
The 9F8992 clutch brake assembly is still available.
Craig
 [attachment=77467]IMG_20231210_0023 - Copy.jpg[/attachment]
Tue, Aug 27, 2024 10:49 PM
17AFarmer
Reply to seiscat:
Craig
Yes there is an adjusting nut for the clutch brake, kind of a big rounded nut on one side nut, I would be willing to bet the lining is shot, those shoes I am sure are available at Cat if not there are aftermarket ones that are just as good I have went to brake shops and had new lining put on and not a lot of money either way
Tue, Aug 27, 2024 11:55 PM
DManring
Reply to 17AFarmer:
Thanks for the reply. I just took mine apart today. Yeah lining gone pin wore out. Call cat they can be here Friday
Wed, Aug 28, 2024 4:09 AM
DManring
Reply to DManring:
Any ideas on clutch brake adjustment proceedure ? Putting it togeather Friday 8-30-2024
Fri, Aug 30, 2024 9:37 AM
seiscat
Reply to DManring:
These are the instructions for the D7 17As, but should be the same as your 3T.
Craig
 [attachment=77485]IMG_20240105_0055.jpg[/attachment]
 [attachment=77486]IMG_20240105_0056 - Copy.jpg[/attachment]
Fri, Aug 30, 2024 8:13 PM
seiscat
Reply to seiscat:
Craig
You really need the OMI for your D7 3T. I found this one for sale cheap on eBay:
https://www.ebay.com/itm/233931480580
Craig
Fri, Aug 30, 2024 8:26 PM
DManring
Reply to seiscat:
Craig
I will look into it , thank you
Sun, Sep 1, 2024 2:50 AM
