D7 17a3130
D7 17a3130
Showing 1 to 10 of 11 results
Pricel
Send a private message to Pricel
I am one push rod ($60.00) away from setting the valves and I also noticed that 2 fuel injection lines coming out of the fuel pumps are weeping a little fuel at the top of the nuts. Question 1--is it best to set the engine valves hot and Idling or hot & shut off? If shut off how do I turn the engine over, it has a lot of compression? Question 2 --I haven't broken the fuel line apart yet but is there any trick to sealing them up? I assume like any fitting like this there is a life expectince but I would like to get these to seal. While waiting on the pushrod I have taken the cutting edge and endbits off one bad blade to be put on the better blade. Cat says not to save the bolts but of course I didn't listen--I found 10 broken bolts and ended up torching off the rest. Thanks
Tue, Dec 4, 2018 10:26 AM
Andrew
Set the tappets with the engine shut off . use the decompresser lever to release compression while turning engine over and release to adjust . there are 3 tappets to adjust . Intake. Exhaust . Compression release . If you cant turn the engine over with the fan , put the starting engine in gear and use the hand crank to turn the engine over .
Tue, Dec 4, 2018 5:05 PM
Thank you received: 62
Reply to Andrew:
One trick to sealing fuel injection lines that has worked for me is warping the line above the tapered seat with Teflon tape. The tape is acting as a spacer to let you push just a little more with the nut.
Be genital with the nut, it is the heavy hand that has been before that has stretched it out. So a just enough thing, none of that just a little more.
Tue, Dec 4, 2018 11:09 PM
mog5858
Reply to Ray54:
some would say that you must annealed the copper washers as the copper work hardens and you will be fighting your self trying to crush a "Hard" washer . i sure someone with more knowledge on this will chine in.
Fri, Dec 7, 2018 7:30 AM
Thank you received: 78
Further to GP's information, the steel collar and/or the seat can acquire imperfections which may be able to be mitigated with valve grinding compound. I used this approach for a couple of situations on my D2 (same concept is used for the fuel supply line from the tank but a larger diameter) but in one case, the compound wasn't enough so I replaced the socket with a new one. If you use the compound on the injector collars, I'd use a very fine paste so you don't "compound" the issue
Sat, Dec 8, 2018 4:35 AM
Pete--do you think the hardening comes about of a rearrangement of the electrons in the D shell? perhaps creating an ion or the molecule Cu2 ??
Sat, Dec 8, 2018 5:41 AM
Ya know---it sounded real good to me too! I was fascinated by quantum mechanics in college, but could never master it!!
Sat, Dec 8, 2018 7:26 AM
Pricel
Reply to dpendzic:
I appreciate all your input--The nuts are very tight--I just bought a set of brake line wrenches and with a hammer broke the nuts loose. Tomorrow I will look at getting the lines off the machine and if no cracks I might try the valve grinding compound, that sounds like it could work. My push rod is in at Cat, but now I ordered a set of nozzles so I may not get it running for another week. The engine could start better and I figure its cheaper to replace nozzle than have someone test them. My last question is--How far can I go down this rabbit hole?? Thanks
Sat, Dec 8, 2018 10:28 AM
janmeermans
Neil,
You best be careful! Someone may get names mixed up after reading "Dummy, don't you know to anneal those things?" and hang you on a coathanger! But right now up there in New York State, maybe the follow-on torch process might feel good! 😊 It would definitely re-arrange your molecules (and a few other things).
JanM
Sun, Dec 9, 2018 12:53 AM
Reply to Pricel:
Judging by my experience with the 5U, the answer is "all the way"....
Sun, Dec 9, 2018 4:27 AM
Hi Jan, it's not too bad actually, a very pleasant 32 with sunny skies, a couple of inches on the ground, my ideal winter's day. Did some sledding with my son - it's all good.
Sun, Dec 9, 2018 4:29 AM
