D7 17A under carrige aviability
wibbdog
Send a private message to wibbdog
are tracks and weld on sprockets still available for d7s 17A the serial number 19000 something
it has a turbo on it I found one and the under carriage is worn out including front idlers are shot as well.
its cosmetically good looking , has elec start pony from the drivers seat. mole board is worn through
just an estimated rough value the way it sits
just curious
thanks
D4 7U 36840
Sun, Jan 31, 2016 5:56 AM
Yes, undercarriage parts are still available, usually purchased after market.
As far as value, unless it's in exceptional condition these old dogs are getting to where they are worth little more than scrap price.
The 17A is a good tractor and worth saving if you don't mind investing some effort and funds.
Sun, Jan 31, 2016 6:12 AM
old-iron-habit
Is the exhaust manifold any good? Most are rotted out by the turbo. They are not available anywhere. I have been looking for one for 5 years with no luck.
Sun, Jan 31, 2016 8:50 AM
Inter674
Reply to old-iron-habit:
Best to convert the sprockets to bolt on segments if you can. Cost me a grand for weld on unused old stock sprockets here in aus.
These are very good machines and like OM said worth saving but track gear will be costly. I paid 9k for one in aus and it needs a lot of TLC. I paid too much but I believe they are one of Cats best and the turbo whistle is worth the money alone! It did come with a massive winch, logging canopy underbelly guard and spare tracks tho.
You might also consider welding up the sprockets as a short term fix - mine are but I will replace them in due course.
Given D8s appear to be going for give away prices in the US I would think a D7 17a would need to be in very good condition to pull more than 5kUS.
Totally different ball game over here tho.
Hopefully they will become collectable one day😊
Sun, Jan 31, 2016 10:05 AM
Tim Matthews
Send a private message to Tim Matthews
Reply to Inter674:
I spent a lot of time welding up my rollers and rails worked quite well. Time or money is your choice. I enjoy running my machine.
Sun, Jan 31, 2016 10:25 PM
