D7-17a tilt blade with No hyraulic unit?
farmermattD7
Send a private message to farmermattD7
I was Nosing around on machinery trader and was looking at a machine that had a cable blade but had hydraulic tilt. it had no front mounted unit like my No.46 on it. Hoses were run down the left side of the engine and went under the platform as far as I could tell. I tried to go back and find a link but cannot find it today.
I am just wondering how they did this? it had the cable unit on the back so no pto pump. did they tap into the steering clutch pump?
I would like to have a tilt blade but dont believe it can be done on a No. 46 so however they did this would work on mine as well I'd think
Sat, Nov 12, 2011 9:25 AM
farmermattD7
Sat, Nov 12, 2011 9:38 AM
Thank you received: 22
Reply to farmermattD7:
here it is I found it on rock and dirt
http://www.rockanddirt.com/equipment-for-sale/CATERPILLAR/D7/invnum=35083436
Back in the day there was a #44 hydraulic control unit that could be mounted on the front of the 17a behind the grill. They were normally a two valve and those are the control reach rods in the guard going down the LH side.
Looks like it has been set up for one valve and I can see the empty hole in the guide block where the other one went.
The system was originally part of the Gyro dozer option for the D7. Pretty rare stuff.
Sat, Nov 12, 2011 11:31 AM
farmermattD7
The more I stared at it I got to wondering if that was the case
so I am guessing there is no two valve option for a No.46 so in turn there is no real good way to have a hydraulic tilt blade on my machine then without a pto pump which i would prefer not to do because I would like to find a cable unit and a pull scraper someday.........
Sat, Nov 12, 2011 11:50 AM
No option on the #46, not factory anyway.
There is still the possibility of front driving a pump but it would be a custom built affair.
There was even an electric drive screw tilt cylinder in the day, what a morfidite that was.
Sat, Nov 12, 2011 12:17 PM
catsilver
I wonder if this is a later blade from a D7E, the D7E, D8H and D9G machines were available with cable control and the hydraulic tilt driven from the transmission pump, using the tranny as a reservoir? The pump location here is a mystery though.
Sat, Nov 12, 2011 11:55 PM
Reply to catsilver:
I remember some years back, going nuts trying to identify this system when I think it was Ag Mike that actually found one. Problem was it is listed in the Parts Manual as a rear mount....no way.
Sun, Nov 13, 2011 12:30 AM
firpitch
Send a private message to firpitch
Farmer matt,
The tilting blade really makes a production machine. I altered my 2U and used the generator drive at the waterpump to power the system. This way it is gear driven with no belts to fool with. The 2U never had the electric start on the pony and as long as the mag is working, it always starts fine with the crank. I can tilt while pushing with no problem. firpitch
Sun, Nov 13, 2011 6:47 AM
Thank you received: 30
Reply to firpitch:
Farmer matt,
Another way of getting it done would be electric powered pump from something like a old lift gate from a truck.Have seen several of these lately being used to run ag equipment.Don't know if it would have enough flow or what electric out put is standard on a 17a D7.But any tilt you can run from the seat beats climbing off and running the manual screw adjuster on early Cat blades.
Ray
Mon, Nov 14, 2011 8:33 AM
