D7-17a stump pan removal
Showing 1 to 10 of 11 results
panner60
Send a private message to panner60
Can anyone give me some advice on the best way to drop the stump pan on a D7-17a crawler? Would I just unbolt it and let it drop or is there a better way?
Sat, May 4, 2013 12:50 PM
D6 Pete
A floor jack with a foot or so of 4x2 timber works good for me!!. ,then lower and drive off.. pete
Sat, May 4, 2013 1:56 PM
panner60
Reply to D6 Pete:
That sounds good, right now its in the bush not running, but I should be able to get it down and drag it out the back. I'm just now in the process of removing the pup motot and switching over to direct start. Thanks.
Sat, May 4, 2013 7:26 PM
d9gdon
Reply to panner60:
I use a ratchet strap and hook both ends to the outside of the track pads with the strap cradling the bottom of the belly pan. Snug it up, take the bolts out of the pan, then ratchet it down to the ground. Make sure that you wind up enough slack in the ratchet when you first tighten it to the tracks.
Sat, May 4, 2013 7:34 PM
ronm
Reply to d9gdon:
Just figure on it weighing a LOT! It will have about a ton of crud in it that wasn't there when it went on...
Sat, May 4, 2013 10:12 PM
panner60
Reply to ronm:
I was under the dozer this morning and yes there is a lot of crud in there. This one is in two pieces and there is a few logs jammed in that I must have backed over. While I'm on here perhaps someone could help me with another question, I just removed the pup motor to change to direct start, and going through the center mount there is a hole going into the main engine from the pup, I'm thinking that it is some kind of drain. I want to know if I can plug it up?
Sun, May 5, 2013 3:00 AM
Thank you received: 21
Reply to panner60:
That drain is the oil return for when the pony had the common oil system.
Should be blocked off when the oil systems are separated or when going to direct electric start.
Sun, May 5, 2013 6:03 AM
panner60
Thanks OM, I'll have to make up a few blanks.
Sun, May 5, 2013 6:55 AM
Tim Matthews
Send a private message to Tim Matthews
Reply to panner60:
I tied off on the limb riser(if u have them) with a couple of cable rachets, worked fine.
Sun, May 5, 2013 9:00 AM
panner60
Reply to Tim Matthews:
Tim - What are you calling the limb riser?
Sun, May 5, 2013 10:31 AM
Reply to panner60:
Front sloping bars leading up to the ROPS cage.
Sun, May 5, 2013 12:48 PM
