D7-17a parts ID
D7-17a parts ID
Showing 1 to 10 of 10 results
anyoldiron
Send a private message to anyoldiron
Hello
l need some pony mag parts, how do i ID the pony/pup motor on my D7-17A? Where is the best place to go for distributor parts?
Many Thanks
Sun, Apr 8, 2018 8:47 AM
gemdozer
Thank you received: 25
The poney motor part number is rear the carburator and do you have a big AMERCAN BOSCH magneto instaled vertical or a WICO CATERPILLAR instaled horizotal and I should have these parts
Sun, Apr 8, 2018 5:52 PM
anyoldiron
Reply to gemdozer:
Hello gemdozer.
Thanks for that. i know the cap is vertical, when it stops snowing i will go get the number.
Sun, Apr 8, 2018 10:55 PM
anyoldiron
Reply to gemdozer:
[attachment=48030]Pup2.jpg[/attachment][attachment=48029]Pup 1.jpg[/attachment]
l need a bunch off bits.
Distributor cap
Points
Condenser
Rotor
Plug leads
Mon, Apr 9, 2018 8:46 AM
gemdozer
Reply to anyoldiron:
Distributor cap
Points
Condenser
Rotor
Plug leads
IT is a low serie and could use too a magneto WICO counterclock wise with long finger
Mon, Apr 9, 2018 5:00 PM
anyoldiron
Reply to gemdozer:
[attachment=48041]IMG_20180409_091413.jpg[/attachment][attachment=48042]IMG_20180409_091418.jpg[/attachment]
Thanks gemdozer, its a brother from many mothers so i could be from a 3T.
do you need to know direction of rotation?
Tue, Apr 10, 2018 9:55 PM
gemdozer
This cap is for AMERICAN BOSCH magneto and have one spair cap and rotor and about the condenser and point have some used but not sure they are better than yours and did you clean point with a fine sand paper and this magneto is turning counterclock wise.
Wed, Apr 11, 2018 1:49 AM
anyoldiron
Reply to gemdozer:
Thanks Gemdozer, where do i find the serial number plate on the magneto, rather, can it be seen without taking off magneto?
Mon, Apr 16, 2018 11:40 PM
gemdozer
The magneto serie plate is on side magneto if she still there and should be MJK 4/2360 C------
Tue, Apr 17, 2018 1:23 AM
anyoldiron
Reply to gemdozer:
Thanks for your help gemdozer!
Thu, Apr 19, 2018 2:00 AM
gemdozer
Make sure you have power on coil before play on point and condansor
Thu, Apr 19, 2018 2:50 AM
