D7-17a oil level
D7-17a oil level
Showing 1 to 6 of 6 results
anyoldiron
Send a private message to anyoldiron
Hello.
What is the correct oil and level for the Dozer blade tank at the front of the tractor?
Please & Thankyouverymuch.
  [attachment=73229]P_20230809_150711.jpg[/attachment]
Fri, Aug 11, 2023 1:59 AM
seiscat
Here's a page from my father's NO. 46 hyd. control book for his D7 17A. I plan on getting it in the library eventually. Oil should be 10W motor oil, add little heavier weight oil if you are in a warmer climate. Let me know if you need more info.
Craig
 [attachment=73231]IMG_20230810_0001.jpg[/attachment]
Fri, Aug 11, 2023 2:53 AM
anyoldiron
Reply to seiscat:
Craig
Thanks Craig.......
But what's the level supposed to be.
Fri, Aug 11, 2023 4:15 AM
Reply to anyoldiron:
Thanks Craig.......
"When oil level is to the top of the filler strainer"
Fri, Aug 11, 2023 4:50 AM
anyoldiron
Many thanks.
Fri, Aug 11, 2023 5:52 AM
seiscat
Thanks Craig.......
Read my attached page again. The oil level is stated on it. Rome K/G's quote is from it.
Craig
Fri, Aug 11, 2023 7:01 PM
seiscat
Reply to seiscat:
Craig
I just posted the Operation & Maintenance Instructions for the NO.46 hydraulic control(for the 17A) on the ACMOC library. I plan on putting more 17A info soon.
Come on board and become a member so you can see it.
Craig
Sat, Aug 12, 2023 5:31 AM
