D7-17A Mag timing
D7-17A Mag timing
anyoldiron
Send a private message to anyoldiron
Hello All
l need some help setting the timing of the Pony motor mag on my D7-17A, long story short its never been up to much and now having seen inside im not surprised, just quite amazed it worked at all for as long as it did.
l have since cleaned up the mag and the advance and retard which now moves properly. lt had a new cap, rotor, points, condenser, plug wires. about 6mths ago and new plugs now. l have put it back together and i have nice alternating sparks. The problem is despite lining up the A and little mark on the gears and also physically removing the mag and rotating it 180, swapping wires both times and trying every variable i can think off i cannot get it to run by ''putting it back to where it was'', i need to start from the beginning.
So, can someone kindly explain to me how to set the timing, right from square one.....................................Oh, and if it helps, i do know my Cat is a ''brother of many mothers''
Cheers AOI
[attachment=56297]P_20191205_082619 (1).jpg[/attachment][attachment=56298]P_20191205_085403 (2).jpg[/attachment][attachment=56299]P_20191205_162527 (1).jpg[/attachment][attachment=56300]P_20191207_084258.jpg[/attachment]
Fri, Dec 13, 2019 8:34 AM
Thank you received: 91
Hi AOI,
maybe the impulse coupling components, with regards the lettering for Direction Of Rotation (DofR) and/or key ways needed for the specific application you need for your pony have been incorrectly orientated--I recall it as very confusing and they can be easily mixed.
It could be possible, without seeing it, that the lug sticking up that the spring assembly connects onto is 180 degrees out to the timing X on the drive tangs or a stamped chisel line on outer edge of the coupling on front of the magneto.
Excerpt from an Engine SRB on the AB MJK coupling that may help.
Usually were written as a general outline and so non specific to engine type--vertical or horizontal-- and D of R non-specific-- so some parts ID regarding the DofR lettering may be shown as incorrect for your actual application, as I feel they could be set for either rotation but I stand to be corrected on this--too long since I worked on one now to be sure.
Hope this helps.
Fri, Dec 13, 2019 9:30 AM
anyoldiron
Reply to edb:
Hi AOI,
Hope this helps.
[quote="edb"]Hi AOI,
Hope this helps.
Eddie B.[/quote]
Hello Eddie.
Thanks very much for that. l dont have the in front of me but i think i know what you mean, l will pull it off tomorrow and report.
Cheers AOI
Fri, Dec 13, 2019 10:09 AM
anyoldiron
Reply to anyoldiron:
Hope this helps.
Eddie B.[/quote]
Hello Eddie.
Cheers AOI
ok.
l have taken it back apart as far back as i went before. in order to rotate the tang thing 180 it now means its impossible to line up the A and strike mark on the gears.
l have set up up 180 different out of absolute %^&ing desperation as im fumbling around in the dark.
For example BOTH my weights have letters stamped on them....................
So, PLEASE PLEASE PLEASE PLEASE PLEASE PLEASE PLEASE PLEASE can some just post direct instructions from the beginning FOR THIS MAG so at least i know im going in the right direction,
Thanks, a very aggravated AOI who has shoveled 300' of 2' snow from his drive
Sat, Dec 14, 2019 12:45 AM
anyoldiron
ok.
.........................now all we have achieved is zero spark.
Sat, Dec 14, 2019 1:19 AM
Hi AOI,
man these things have always been a head ache with dual usage of parts for either rotation--I recall similar issues after dismantling one and washing the pen marks I dutifully put on everything off.
The text is some 19 pages for the entire magneto section for the AB unit.
Quickly scanning thru I find the last paragraph says that :-
"a magneto housing with a part number ending with an even number is a clockwise rotation set up and those with an part number ending with an odd number is for anti-clockwise rotation"
It also says elsewhere that the direction of rotation is shown by the arrow on top of the magneto.
The Points cam gear should have either an A or a C stamped into it--as these are a direction specific item then the A or C marking should give an indication of the actual D of R for your magneto.
Am time strapped at present do help much further.
Hope this helps--if you changed anything in the impulse coupling area and the impulse is not working when on the engine it tells what needs to be changed back.
If you have simply lost spark then maybe clean and check points are set within 0.014"-0.018" I like to keep the points set to as close to 0.015"-0.016" as I can.
Sat, Dec 14, 2019 5:37 AM
anyoldiron
Reply to edb:
Hi AOI,
Thanks for all your efforts Eddie,
lve found with this older stuff there is an ''assumption of prior knowledge'' in the literature, i struggle with it, which is a little odd considering.
The long and short of it was i lost the spark by poorly reassembling it and shorting it.
The culprit ended up being the coil, which as they tend to do tested fine and then started to fail when used............................well, it had to be everything else is new 😉 Then there was some confusion over the timing , which was fixed with a ''one last hail Mary try'' before i either set fire to it or hit it with something large.
As a ''reward'' LOL, heres a pic of what it gets to do..........and do well!
Cheers AOI
[attachment=56672]P_20200104_155444.jpg[/attachment]
Mon, Jan 6, 2020 8:15 AM
Thank you received: 76
Cheers AOI
I noticed in Eddie's scan that it stated to reassemble with using the C mark, not the A mark, when both are present. Could that have been / be a factor?
Mon, Jan 6, 2020 8:50 AM
Hi AOI,
well done that man. These things are always throwing a curved ball at us.
Yes, the literature is ambiguous and photos on the phone are essential before a dismantle is undertaken--never had that luxury back in the '60's had to do own diagram.
Aged coils are always a lottery as you found.
Enjoy the pushing.
Mon, Jan 6, 2020 11:43 AM
