D7 17A Front Idler Replacement
Showing 1 to 10 of 11 results
TOP
Send a private message to TOP
I am looking for thoughts on how to do this repair.
I had a front idler disassemble itself yesterday in a most inconvenient location. Now I need to find a replacement for both of them because if one goes the other is not far behind.
I don't know whether anyone has seen a setup like this, but close inspection will show it was bound to fail. Hindsight is indeed wonderful. It appears somebody rolled up a 3" wide C-channel and welded it between what what left of the top of a front idler tire. No matter that CAT calls for the center rib to be more like 4" wide.
What I have done so far.
1. Spent a lot of time in the parts book.
2. Talked to a CAT repairman
3. Talked to some aftermarket vendors of undercarriage parts.
4. Looked at the casting number on the track links. Berco CR 1775 which nobody has heard of.
5. Got a quote for new idlers (salty.)
6. Contemplated a proper repair (materials would be hard to find. )
7. Kicked myself for not seeing a big warning sign before I got the machine into an awkward place.
What I need to find is a pair of idlers with some life left in them or a way to repair what I have. I believe mine have bushings for bearings (slide on grease fitting). How to get them off has been covered in the forums.
The other thing is how to recover the machine from where it is. Since there is no rib on the idler now, throwing a track is very likely. Since I was making a cut on a sidehill there is no room to work on the track where it sits. To get out of there I have to back up quite a way and make a 180 degree wide turn. Any thoughts on moving a machine in this condition? The dozer arm is close to the edge of the track and it might help keep it from completely falling of the idler.
Sat, Nov 21, 2026 4:31 AM
Thank you received: 95
Wow, what a mess you have there, first thought is to try and get the U segments out and grind the welds from each side of them with a battery angle grinder. Then weld back in the truer of the segments of the center rib back in place temporarily with a portable welder to get you out of there. Maybe segmentise the badly distorted bits to get as much rib to tack back in as you can.
That idler is likely a "Will-Fit Part" by the construction of it.
Cat idlers have a forged/rolled one piece rim section.
Sat, Nov 21, 2026 7:44 AM
Thank you received: 227
Your photo does not show the front side of the idler - is there enough depth in the rails that the idler will stay riding on the bushings and that too depends upon how loose the track is now. It looks like it went for a way before you noticed it? If you had been running for a bit with the damage, someone assisting by watching the track and slow movements MAY give you a chance to carefully back it out of there? Your big issue will be turning and the side hill. You certainly do not want to throw the track off the bottom rollers! Stresses are heavier with the dozer blade in place. Can you drop the dozer blade in place, remove that weight? - cts
Sat, Nov 21, 2026 4:44 PM
TOP
Reply to ctsnowfighter:
It let me know something was wrong right away. Maybe 3 ft was all it took to get my attention.
How about the front side from the inside looking forward? I caught it pretty quickly and came to a stop. Better to think my way out of this.
As for the dozer, it may be a plus. I have an idea after reading your comment. It is obvious the dozer has to come off to break the track. But for the ride back the dozer is close enough it could prevent a catastrophic derail. Even better would be to make a guide that bolted to the dozer and guided the track shoes kind of like a caliper surrounds a brake disk. An inch of clearance on each side would still keep things from going too sideways.
The center rib is completely gone as far as I can tell. It was just a bit of rolled 3 inch channel. The 3 inch width is probably what brought this on. The CAT refurbishment spec calls for a 4 in wide rib. I think the track tried to climb the rib and punched out the flakey welds they had done. One piece of channel is still jammed between the two sides of the idler disk.
I think the weight in the front is a plus as it will tend to keep the front roller fully engaged with the track. I don't remember the rules for getting thrown track back on though I had to do it with a TC12 that was in dire need of new track many years ago.
@EDB
If you know where I can get those forged rings I would be quite interested. ^^ CAT wants $2K a pop for those idlers.
Sun, Nov 22, 2026 12:56 AM
TOP
Reply to edb:
There are no truer segments. Looks like pretzels and then there is the matter of a welder. For shame, I don't have one, not even a plug in the wall model. But that is a good idea. I could probably recover enough to place a piece every 15 degrees. Excuse to buy a gas powered welder. Hmm, maybe.
Sun, Nov 22, 2026 1:04 AM
Maybe hire a gas/diesel welder or chase a mate with one to come assist if you are not comfortable using a welder.
No one said this temporary repair would be easy in situ.
Amongst the first things mentioned about in some of the old Grey OMI's that it is the operators responsibility to check the machine daily for fluid levels, loose, bent rubbing etc. components! Yep sometimes easier said than done.
As an Australian Army Engineer Plant Operator in Vietnam I used to check my machine at morning start up for by looking underneth for leaks and loos, rubbing, failing components and booby traps.
Checked it over again after smoko, lunch break and end of day before shut down during idle cool down period when oils were warm and adjust levels if required. Also checked radiator core for debris clogging if working in foliage etc.
The list can go on and is time consuming but is vital for trouble free operation and longevity at minimal cost.
Regards,
EDIT the idler cutaway view is for explanation by Cat themselves--that centre section is not available separately as it is a part of the idler assembly as it is sold.
Sun, Nov 22, 2026 2:13 AM
Photo appears that the inside rail is already on the outside of the front idler. I do not think you will have much luck trying to keep the track on by attaching anything to the push arm on the dozer. You have a lot of slack in that track, nothing is going to keep it tight. Loose tracks do not stay in place, especially when traversing rough & uneven ground. I would consider having someone that understands the way track is supposed to run and then trying to back it out of there. Going forward you are on the loose side of the track running over the top of the non existing idler. There is nothing to guide it once it passes the top carrier roller. Nothing lost if you find that it won't track, quit before you throw the track off! ( Not sure how much adjustment you have on that track - at this point, you might also look at getting the idler back between the rails and see if you can get the track tight enough to keep it riding on the bushings, rails on each side of the idler. You are not going to be going far enough to hurt the bushings, slow and gentle! Certainly not orthodox but at this point you are between a rock and hard place!) Breaking the track (removing the master pin) is not the hard part of things with the dozer arms attached, putting it back together is the trick! I would not want to break that track in the position and conditions you say you are in. That would just compound your problems. I do agree with Eddie B -- a pro welder with the proper equipment may be able to fabricate something to get you out of the woods. This is no time or place to have a weld fail. - cts
P/S your first photo of the idler, if you only went 3 feet, look at the rest of the running gear, what is chewing on the ends of the pins? Bright shiny area shows. - cts
Sun, Nov 22, 2026 2:40 AM
TOP
The rails are still centered on the idler. The picture through the center shows that too.
Yeah something is rubbing on the sides of the rails. Maybe worn rollers.
I took a rough measurement of the idler and it is below spec. With the worn master pin there may not be enough adjustment left. It isn't floppy loose though.
I think I am looking at a new chain. This one is Berco and they can't even find it in their books. The reason is that the master pins and links are shot and can't get replacement links. I found chain that costs about what CAT would charge to replace the master links. And it is only 70 years old.
EDB's idea of welding sections of the old C channel back in may get me out of there.
If I can get something to anchor the winch to it can be dragged with the track locked.
Sun, Nov 22, 2026 8:26 PM
Do you have the logs or other materials that could be set up as a sled, much like was used for the Steam Donkey Engines in the woods in days gone by. Might be easier on the machine and you. You then could anchor your winch line, a snatch block would be helpful too. Always a way to work around problems, sometimes just have to back off and think about the issue. Keep us posted on your progress. Good Luck! - cts
Mon, Nov 23, 2026 12:22 AM
D8Dude
Thank you received: 28
If it were me, the fact that it's still on the idler completely, and if the rollers flanges are rubbing on the pin bosses it's got a pretty good chance of staying on the rails, I'd pull all the broken bits out and have a crack at backing it out really slowly, even more so if I had someone spotting for me, the track doesn't look excessively slack. Turning very gently keeping that track stationary each time you turn, I would say you will get it somewhere easier to work on it without over complicating things.
Mon, Nov 23, 2026 10:59 AM
TOP
Reply to D8Dude:
That is a thought. Turning gently is the problem. It has to back up a tight switchback that just fits the dozer. And it is not yet very smooth because of some shale outcrops that need a ripper to remove.
I considered renting a big Case with a ripper to smooth that out and assist in moving the machine. That could be an anchor for the winch too.
The roller flange contact with the pins points to the need for roller rebuilding or replacement too. But I am still partial to welding pieces of the C-channel back into the idler as insurance.
Wed, Nov 25, 2026 2:04 AM
