I am looking for thoughts on how to do this repair.
I had a front idler disassemble itself yesterday in a most inconvenient location. Now I need to find a replacement for both of them because if one goes the other is not far behind.
I don't know whether anyone has seen a setup like this, but close inspection will show it was bound to fail. Hindsight is indeed wonderful. It appears somebody rolled up a 3" wide C-channel and welded it between what what left of the top of a front idler tire. No matter that CAT calls for the center rib to be more like 4" wide.
What I have done so far.
1. Spent a lot of time in the parts book.
2. Talked to a CAT repairman
3. Talked to some aftermarket vendors of undercarriage parts.
4. Looked at the casting number on the track links. Berco CR 1775 which nobody has heard of.
5. Got a quote for new idlers (salty.)
6. Contemplated a proper repair (materials would be hard to find. )
7. Kicked myself for not seeing a big warning sign before I got the machine into an awkward place.
What I need to find is a pair of idlers with some life left in them or a way to repair what I have. I believe mine have bushings for bearings (slide on grease fitting). How to get them off has been covered in the forums.
The other thing is how to recover the machine from where it is. Since there is no rib on the idler now, throwing a track is very likely. Since I was making a cut on a sidehill there is no room to work on the track where it sits. To get out of there I have to back up quite a way and make a 180 degree wide turn. Any thoughts on moving a machine in this condition? The dozer arm is close to the edge of the track and it might help keep it from completely falling of the idler.
Wow, what a mess you have there, first thought is to try and get the U segments out and grind the welds from each side of them with a battery angle grinder. Then weld back in the truer of the segments of the center rib back in place temporarily with a portable welder to get you out of there. Maybe segmentise the badly distorted bits to get as much rib to tack back in as you can.
That idler is likely a "Will-Fit Part" by the construction of it.
Cat idlers have a forged/rolled one piece rim section.
Your photo does not show the front side of the idler - is there enough depth in the rails that the idler will stay riding on the bushings and that too depends upon how loose the track is now. It looks like it went for a way before you noticed it? If you had been running for a bit with the damage, someone assisting by watching the track and slow movements MAY give you a chance to carefully back it out of there? Your big issue will be turning and the side hill. You certainly do not want to throw the track off the bottom rollers! Stresses are heavier with the dozer blade in place. Can you drop the dozer blade in place, remove that weight? - cts
