d7 17a exhaust elbow
Showing 1 to 6 of 6 results
powersmoke18
Send a private message to powersmoke18
anyone have a cat part number 8m3539 laying around? or know of anyone who can reproduce one? the one on my 7 looks like a puzzle that was welded together by a blind man.
Fri, May 9, 2014 1:08 AM
cat_d7_17a
Send a private message to cat_d7_17a
A good welding shop can build you one. If I had the dimensions or yours I could build it, but I don't know where your from. I am a certified welder and have a shop.
Sat, May 10, 2014 11:06 AM
powersmoke18
Reply to cat_d7_17a:
Im in nj. I am currently working with cat on trying to procure the blueprint or I may just have to fabricate it out of regular exhaust tubing and machine a bushing to connect it to the turbo.
Tue, May 13, 2014 6:48 AM
cat_d7_17a
Reply to powersmoke18:
I wouldn't use that thin exhaust pipe. Go to a plumbing supply store and buy a weld type 90 degree elbow. They use them for gas lines and such. They already have a bevel built into them for welding and no threads. Buy you a short piece of schedule 40 steel pipe the right size for your muffler to fit over while your there. 3 1/2" schedule 40 is 4" on the outside. Torch/plasma you out a flange and drill your holes to match the one you have and start welding.
Tue, May 13, 2014 7:21 AM
powersmoke18
Got the blue print today. Seems easy to make except for the whole 4" to 5.30" tapered elbow bit.
Tue, May 13, 2014 11:08 PM
Thank you received: 23
Hi Powersmoke, what's the process for obtaining blueprints? Do you go through the dealer or do you contact head office?
Tue, May 13, 2014 11:29 PM
powersmoke18
used the microfilm to obtain the part number because mine is non existant. then the parts guy sent an email to corporate. a few days later i had the print. he said he was rather suprized at how easy it was. usually they dont give that information out. its kind of a parts patent issue i guess. can't give out to much info. but i'm also not a asian company looking to rip off cat. :tape:
Wed, May 14, 2014 4:22 AM
