D7 17A Engine Weight
Dick Tucker_archive
Send a private message to Dick Tucker_archive
What does the engine on a D7 17A serial number 16035 weigh?
Wed, Jan 15, 2020 12:19 AM
Around 4500lbs
Wed, Jan 15, 2020 9:56 AM
Dick Tucker_archive
Around 4500lbs
would 4500 lbs include the poney engine and main engine clutch?
Wed, Jan 15, 2020 9:17 PM
Reply to Dick Tucker_archive:
Around 4800-5000 then to be safe.
Wed, Jan 15, 2020 9:35 PM
Dick Tucker_archive
Rome I have a JD 410B backhoe that I was planning to use to remove the engine but I think 5000lbs might be more than it can handle. How much weight would be reduced if I removed the heads, exhaust & intake manifolds and pony motor before removing the main engine?
Wed, Jan 15, 2020 10:47 PM
If you can get close enough to the engine it may work, yes removing the heads and starting engine will help some.
Wed, Jan 15, 2020 11:03 PM
| Kingaroy, Queensland
