d7 17a Electric Starter Conversion
Showing 1 to 10 of 42 results
bctimber
Send a private message to bctimber
after researching the search eng on this site for the swap there a lot of info here what a great site. i guess OLD MAGNET is the guy i need, my ser # is 17a5425 what do i need. i can do some basic fabricating. thanks shane
Tue, Jun 8, 2010 9:40 AM
Basic starter needs are a Delco Remy model 40MT, 42MT or the larger 50MT 24v clockwise rotation starter with the RH helix drive gear (not LH) and the adaptor housing. The adapter housing and drive is available at
http://stores.shop.ebay.com/Triodiode-DC-Electric-And-Tractor__W0QQ_armrsZ1 or from other sources.
That's just the beginning....add switches, wiring, batteries, battery box, block off plates for the old pony, etc
Then there is the generator/alternator matching and glow plug chambers and glow plugs from the later 17a models.
Here are a couple of pictures of the 17a setup.
Tue, Jun 8, 2010 9:43 PM
bctimber
Old Magnet you are the man I thank you. that delco alt how is that attach to the old gen.here is a deferent problem i have now all last year i park on a hill and roll start, or pull start off the winch like a lawn more with my backhoe. any way it sat on the hill all winter in 1 gear right brake on in revers went to roll start it and will not move got nabers dowser pushed and pulled no go, lock both tracks ,all the gears feel like they are there seems like its in 2 gears . with the winch engaged and the trans in 1 or 4 it is lock allso . any ideas
Tue, Jun 8, 2010 10:33 PM
Reply to bctimber:
Check the transmission interlock, linkage, etc.
Not to uncommon for these to get out of adjustment or stuck.
I'm not that familiar with that particular alternator mount but I suspect there would be a machined flat surface where a circle of fasteners could be attached, much like you see for the mounting flange. It's a little more common to use an adaptor that mounts up to a Motorolla flange using the Motorolla to Delco alternator front housing. Inside the adaptor will be a flex coupling, usually Lovjoy type. Also should have a cooling fan.
Wed, Jun 9, 2010 3:02 AM
bctimber
interlock, linkage,is this the piece on the right hand side of the trans with the 4 springs and dentins set up, 6 bolts.if so all good be for i seen the pic of that ALT i was thinking of mounting an delco on top of a gutted GEN with a pulley set up.
Wed, Jun 9, 2010 9:55 PM
Reply to bctimber:
Yes, that is the location. Detent plungers need to be in right position or you can't shift any gears. You can try disconnecting the linkage and moving lever by hand before "going in".
Mounting an alternator to a converted generator/pulley is a pretty common approach and works fine. Not as clean as a direct mount but every bit as functional.
Wed, Jun 9, 2010 10:17 PM
bctimber
thanks for all the info Old Magnet . as i gather up stuff will probably ask more of your knowledge thanks shane
Fri, Jun 11, 2010 10:04 PM
bctimber
Reply to bctimber:
well i phoned Weitzel's D.C. Electric on ebay they are not Sher what i need, 11 or 12 tooth drive and witch housing, do you have some # handy . Shane
Fri, Jun 11, 2010 10:31 PM
Reply to bctimber:
Their stock number for the drive gear is #12197
The adaptor housing is #12144
Sat, Jun 12, 2010 2:46 AM
bctimber
once a gain thanks.
Sat, Jun 12, 2010 9:52 AM
bctimber
Reply to bctimber:
once a gain thanks.
it was the right brake stuck on . it's now up at the shop time to pull out the pup and put in the mt 40.
Fri, Jun 18, 2010 9:30 PM
Newby Hall Tractor Fest
