D7-17a Direct Start
D7-17a Direct Start
Showing 1 to 10 of 15 results
955H
Send a private message to 955H
I did a direct start conversion this summer on my D7 and now that the cold weather is rapidly approaching I have a new concern: winter starting.
CAT dealer up here recommends 10W30, but its going to take more than winter weight oil for cold starts, the old girl starts really well and I think that a block "warmer" would take care of it but Im a little leary. I saw someone using a Herman Nelson type heater but worry if it was placed too close to the block it might actually over heat the block? is that a legitimate concern?
KEVIN JOHNSTON
955H, D7-17A, JD 540 SKIDDER W/JD BACKHOE ATTACHMENT AND LOTS OF COCKSHUTT TRACTORS
Thu, Oct 1, 2009 9:07 AM
SJ
Send a private message to SJ
I think I,d look into a regular block heater that heats the coolant and would work the best I,d think.
Thu, Oct 1, 2009 6:04 PM
u-joint
Send a private message to u-joint
Reply to SJ:
did you convert per caterpillar? 12 or 24 volt, what do you have for batteries?
i have been told that these old gals start much better with direct electric
than pony engines. i do not think you will have problems. you can always give
it a snort of ether if need be.
i do not think a block heater cobbed in the system would hurt your block.
cast iron melts around 2000 degrees, your rubber hoses will be on fire before
your block melts. the only other way to hurt cast iron is to hit it real hard
with a hammer!
Sat, Oct 3, 2009 3:20 AM
Reply to u-joint:
with a hammer!
Is the Herman Nelson heater one of those direct fired units?? seems to be a little overkill unless you have no other source of power for a block heater. Can't be any colder than where King of Obsolete lives and he gets by on ether assist for his DE starters.
Sat, Oct 3, 2009 3:27 AM
955H
Its a 24volt Delco 80MT starter (IT WEIGHS A TON!!!!) yes if King of Obsolete can start with ether i guess I"ll be "OK", I'm not quite as far north as him. I used #2 welding cable and kept the batteries within a foot or so of the starter so I didnt have too much amperage drop. I bought 10W30 oil that CAT recommends but i worried that those cold starts would be hard on the old girl.
KEVIN JOHNSTON
Sat, Oct 3, 2009 8:57 AM
955H
Reply to 955H:
Yes, sorry, Herman Nelson heaters are a diesel fired portable heater, produces about 1,000,000 btu's
KEVIN JOHNSTON
Sat, Oct 3, 2009 9:04 AM
u-joint
Reply to 955H:
a million BTU's, good god! that would melt cast iron! it sounds like you did
a quality conversion. i believe you will be happy with it this winter.
Sat, Oct 3, 2009 9:14 AM
Reply to u-joint:
I believe that's a 50MT....never heard of a 80MT😊 😊
All you can do is try it.....the portable heater can be plan B if you need to.
Sat, Oct 3, 2009 9:21 AM
skywagon70
Send a private message to skywagon70
Reply to u-joint:
If you have power you can put a heat lamp on the block just keep it back a few inches and away from combustables throw a tarp over the hood and let it hang down over the radiator and behind firewall. this needs to be done several hours before starting, preferably the night before.
keeping it covered does a lot to hold warmth
total cost pbly less than $50
Butch
Sat, Oct 3, 2009 9:30 AM
Old 3T lover
Reply to skywagon70:
Butch
I haven't ever had to deal with tempertures below zero F. But if it was a usual winter time thing for me, I believe I'd seek some information on thinning the oil in the clutch and transmission also. They will both add drag on the starter when cranking.
Be sure transmission is in "neutral" when starting when it's cold. I've seen "oil Clutch" machines "take off" even with the clutch disengaged.
Sat, Oct 3, 2009 8:04 PM
955H
Reply to Old 3T lover:
maybe I got it wrong (80MT) I'll digup the receipt, I got it from Reynolds Electric part of Reynolds museum they sold it as a rebuilt saying that they were no longer availble new. If the heat lamp idea works, would magnetic block heaters be "ok"? My 955 has its own block heater but I have a bunch of 250 watt magnetic block heaters, could I run a couple of them? and should they be on the pan or block??
KEVIN JOHNSTON
Sat, Oct 3, 2009 9:21 PM
