d7 17a / d8 14a
d7 17a / d8 14a
Showing 1 to 6 of 6 results
lil cat mec
Send a private message to lil cat mec
what are the proper adjustment procedure for adjusting the steering clutch's and brakes?
1935 CAT 22 2F4455W
1990 CAT D6H 4GG04120
2012 CAT 272C RED02823
1971? CAT 951B 86J01212
Wed, Jun 1, 2016 12:25 PM
lil cat mec
So the owner already had a new used idler for the 8, but its not the same one, the one off the machine is a 8f-1978, the new one is a 9h7521, the new one doesnt have the same mounting blocks on the side, also there are no grease fittings, is this one oil filled and sealed? Can the mounting blocks be removed and swapped?
1935 CAT 22 2F4455W
Sun, Jun 19, 2016 10:35 PM
gemdozer
Thank you received: 25
Reply to lil cat mec:
I am't sure but should't have the same shaft and bearing should't fitt on
Mon, Jun 20, 2016 2:50 AM
lil cat mec
Reply to gemdozer:
Any ideas? Do the blocks just press off? I may try and find a press to use if nothing else
1935 CAT 22 2F4455W
Tue, Jun 21, 2016 9:54 PM
gemdozer
The block bearing 8f1978 should be just press on shaft
Wed, Jun 22, 2016 12:44 AM
lil cat mec
Reply to gemdozer:
Good to know! So knowing that info, im going to try and get the block off probably friday and get them swapped over
1935 CAT 22 2F4455W
Wed, Jun 22, 2016 12:34 PM
lil cat mec
The old block was cracked so i just made the new one work, would anyone be willing to tell me how to adjust steering clutches and steering brakes as well as the main clutch on both the 7&8?
1935 CAT 22 2F4455W
Sun, Jun 26, 2016 12:18 AM
