D7 17A clutch brake
D7 17A clutch brake
Showing 1 to 7 of 7 results
rustyfender
Send a private message to rustyfender
any ideas on relining my clutch brake shoes?
Thu, Aug 22, 2013 5:20 AM
Tim Matthews
Send a private message to Tim Matthews
Just buy the lining and rivit it back on .
Thu, Aug 22, 2013 5:49 AM
Reply to Tim Matthews:
You can get the lining from Cat and have a clutch and brake shop assem it for you.
Thu, Aug 22, 2013 6:56 AM
McMaster Carr has sheets and strips of various thickness and friction grades. Pretty cheap too if you don't need a lot of surface area. Most likely have rivets too.
Thu, Aug 22, 2013 7:59 AM
rustyfender
local cat dealer has the parts, not a lot about this in my book about re and re. from machine, any help greatly appreciated
Thu, Aug 29, 2013 6:14 AM
If you're asking, it must not be the simple external shoe rubbing on a drum that bolts to the short/duplex universal joint connecting the clutch and transmission that was used on the later D6.
Sorry, never looked at a 17A clutch brake.
Thu, Aug 29, 2013 9:42 AM
proceedure below is scaned from the the Service Manual.
The Adjustment proceedure is in the gray OMI.
Hope this helps.
Thu, Aug 29, 2013 1:07 PM
rustyfender
Reply to edb:
Hope this helps.
now that I have seen this and I have the new one in my hand it makes sense. thanks guys
Fri, Aug 30, 2013 7:01 AM
