D7-17A balance shaft
homesteader57
Send a private message to homesteader57
I need help in an explanation of how to replace balance shaft in the d7-17a motor as it appears to have broke
Fri, May 6, 2011 8:02 PM
Hi homesteader57,
welcome to the BB.
Here are some scans that should help you to do the job after you have blocked up the front of the machine to get 12" between the equalizer spring support and the frame rails, and removed the oil pan.
Sorry for quality of scans as book has been wet at some time.
See how these scans help, and ask away as needed if, they are not all that you need.
You have some heavy work ahead of you with this one.
PS grab these while they are up as we need to remove them later to post more data. Also the order they load is beyond my control so what order you get is it.
Sat, May 7, 2011 8:01 AM
bob
Send a private message to bob
You need to take down the front section of the oil pan. Then you can remove the front support for the shaft and then take down the pump and ballancer unit. The pump and ballancer section is HEAVY. Take it all apart and look for anything that might have jammed up the gears and broke the shaft. Going together mount the pump and leave the drive gear and shaft hanging. Set the ballencer weights at bottom and lock with a bolt. There is a hole for this. Then put any cyl on TDC. Should be marks on flywheel under square cover. Then put support up meshing the drive gears and remove the lock bolt. The ballencer weights must be timed together and they turn at twice crankshaft speed. Everytime a pair of pistons are at tdc the both weights are at bottom.
Later Bob
Sat, May 7, 2011 8:10 AM
| Hartley - South Australia
Newby Hall Tractor Fest
