D7-17A #18538 OIL CLUTCH
adwest77
Send a private message to adwest77
Is the oil clutch adjusted by screwing big ring in toward the back of engine or out toward transmission. I am not really getting a definite  snap on engagement. Ring is flush hub now. Long story short had it completely apart all new bearing and bushings the disk looked good just wondering if something could have been put back wrong any advice greatly appreciated.
Sun, Feb 16, 2025 9:06 PM
gemdozer
The oil adjusting cluch is clock wise and if you give to much she will not snap on the lever you need too desajuste a little bit and try to snap until you find the good adjustement and dont forget to tight the nuts
Tue, Feb 18, 2025 1:56 AM
adwest77
Reply to gemdozer:
Thanks gem dozer we had it screwed all the way out and then all the way in to flush but never really found a spot that felt like a good snap when engaging. That what got me second guessing it.
Tue, Feb 18, 2025 4:08 AM
