D7-17a #18538 cable to hydraulic requirements
adwest77
Send a private message to adwest77
Will the hydraulic assembly such as the nose cone and cylinders off of a 3t swap on a 17a cable dozer. Is there anything I'm forgetting to look at in this swap have already on a donor machine.
Sun, Feb 9, 2025 10:00 PM
Thank you received: 51
I know the width of the frame rails changes from 3t to newer ones. But don't know which models, so take your tape measure. And if you don't mind some cutting and welding. The next thing to look at is the pump drive.
Mon, Feb 10, 2025 7:01 AM
Thank you received: 271
Reply to Ray54:
I had a 17A to sell some time ago, and from memory, the width of each machine was the same. Intended buyer wished to swap over from a 3T to 17A as well. Good luck. JM
Mon, Feb 10, 2025 10:46 PM
adwest77
Thank you juiceman and ray54 for your information.
Thu, Feb 13, 2025 6:26 AM
