D6D uses 2 quarts per hour
Showing 1 to 7 of 7 results
crbearden
Send a private message to crbearden
My D6D is finally running again.  I have a bunch of oil slidge to still get out of the radiator.  It also uses a gallon of oil every 3 hours.  Is there a cheap motor oil that can be used in the 3306.  At the time of manufactur I don't think the multi grade olils were available.  Would a straight 40 W  work if found at a price I can afford?  An 8 hour day will take 4 gallons.  Re-ringing is a time and expensive job...
Fri, Jul 16, 2021 11:00 PM
bursitis
15w40 is pretty standard oil for the D6D. i don't think 40 weight will help much. one thing though--- change the inner and outer air filter. you could be sucking oil around the turbo bearing seals. does the engine have blow by???
Sat, Jul 17, 2021 1:03 AM
Reply to bursitis:
Gees! sounds like the pistons dont even have rings on them!
Sat, Jul 17, 2021 2:39 AM
Glum
Sounds like a rebuild will work out cheaper than the volume of oil you need pretty quickly.
Sat, Jul 17, 2021 11:25 AM
Thank you received: 93
Reply to Glum:
do you have a link or links to previous posts that may enlighten us to what work you may have done to this engine/machine in the past or recently to get it going again so then we can decide on a cause or some other problem and place to look for a help solution ?
You know your machine better than we do and its history as we deal with many machines and problems most days on here and so have trouble recalling your particular case.
Regards,
Sat, Jul 17, 2021 12:31 PM
Wombat
Donor
Reply to edb:
Regards,
I was told oil consumption at 2% of fuel consumption was rebuild time.
Wombat
Sat, Jul 17, 2021 3:07 PM
seiscat
Do you know the hours on that 3306? The reply from bursitis about the air filters is a good start. I know an overhaul is expensive but please bear in mind that high hour 3306 engines are known to break valve springs. A local independent repair shop had a D6H in this year that had a catastrophic engine failure due to a high hour valve spring failure...the block, crankshaft and cylinder head were all damaged beyond repair!
All valve springs should be replaced at overhaul time.
Craig
Sun, Jul 18, 2021 12:14 AM
bursitis
Reply to seiscat:
Craig
i suspect an oil leak of turbo seals are out. it must be a mosquito killer???
Sun, Jul 18, 2021 1:40 AM
