D6D Transmission service door jammed
Kwright
Send a private message to Kwright
I have a problem that I need you professionals to help me with. The transmission servicing door mechanism is jammed. I cannot get the latching mechanism to release the door. I removed a access panel on top of the structure above the door but I cannot get the mechanism to release. I noticed a spring and a broken piece of metal inside.
I removed the latching handle on the outside, however the latching mechanism will not release.
Should I remove the hinge pin?
Any help would be appreciated.
Kenny
Thu, Oct 18, 2018 7:42 AM
buch933
Send a private message to buch933
Do you have an access panel on top(6 bolts or so), next to your right arm rest. If so, you can reach through and open latch from inside.
Tom
Thu, Oct 18, 2018 7:16 PM
Kwright
Reply to buch933:
Tom
[quote="buch933"]Do you have an access panel on top(6 bolts or so), next to your right arm rest. If so, you can reach through and open latch from inside.
Tom[/quote]
I do, after removing that’s when I saw a broken piece with a spring on it, not sure how to make the latching mechanism release though. Any ideas?
Thu, Oct 18, 2018 9:57 PM
