D6D powershift sometimes doesn't want to go in reverse
Showing 1 to 10 of 107 results
Jfehrle
Send a private message to Jfehrle
I recently acquired a D6D lgp dozer.
After running it hard for a couple hours it will run hot into the red a little (but never boils over or looses coolant).
Sometimes when it's that hot when I shift the powershift to reverse it will try go but won't have any power. If I shift it back to neutral and then back to reverse usually it will take off, sometime I might have to do this twice. Also it seems that if I idle the engine all the way down it will go in reverse for sure. It doesn't have any problems between gears it's just the forward to reverse (and never reverse to forward).
Does anyone have any ideas on where to start with troubleshooting this?
Should these tractors run this hot or do I need look at trying to get the temperature down?
What would cause the powershift to not go into reverse after a couple hours?
Sun, Oct 1, 2017 9:12 AM
seiscat
Hi Jfehrle, Do not run that tractor into the red, you are risking major damage and expense by doing so. Being a little in the red is kinda like being a little pregnant. That is a good looking D6D LGP. Not too long ago I was asked why a recently purchased local D6D ran hot; the answer was easy, that tractor had engine enclosures but had a solid hood which caused the problem. I couldn't tell from the pic if your D6D had a perforated hood (holes like the side panels) or not. If you have a perforated hood the first thing to check is the radiator cooling fins, if you look from the engine side can you see daylight through the fins? Are the fan belts worn/loose? Are the belly pans clean?
I am also concerned that you did not say what the torque converter temperature was. The D6Ds will typically have the torque converter temp be higher than engine temp and cause the engine temp to rise. Is your torque converter temperature gauge working? If your engine is in the red the torque converter should also be in the red. This might explain the transmission problem.
Welcome to ACMOC. If you allow your profile (upper right corner) to show your town or general location there might be members nearby that can help.
Craig
Sun, Oct 1, 2017 8:45 PM
Jfehrle
Reply to seiscat:
Craig
Seiscat,
Wow I would have never thought about the ventilation through the doors! I'm pretty sure it doesn't have a perforated hood. Even if it does it's been repainted a couple times and all the holes could be plugged in the side doors and the hood. Next time I try to run it I'll take the engine doors off and see if it runs cooler that way. If so that may fix everything.
The torque converter temp gauge follows the engine temperature up but doesn't go into the red. (I'm not 100% sure it's working correctly.) Is there a test port I run a line to just to make sure the reverse clutch pack is getting enough pressure? I sure wouldn't want to burn up a clutch in there just because it's not getting enough pressure.
I'm located in Plantersville, TX which i north of Houston.
[quote="seiscat"]Hi Jfehrle, Do not run that tractor into the red, you are risking major damage and expense by doing so. Being a little in the red is kinda like being a little pregnant. That is a good looking D6D LGP. Not too long ago I was asked why a recently purchased local D6D ran hot; the answer was easy, that tractor had engine enclosures but had a solid hood which caused the problem. I couldn't tell from the pic if your D6D had a perforated hood (holes like the side panels) or not. If you have a perforated hood the first thing to check is the radiator cooling fins, if you look from the engine side can you see daylight through the fins? Are the fan belts worn/loose? Are the belly pans clean?
Craig[/quote]
Mon, Oct 2, 2017 8:07 AM
Reply to Jfehrle:
Seiscat,
Craig[/quote]
Lots of things to be checked for over heating or running hot before you get to transmission/torque converter pressure checks. Get one of those Harbor Freight $20 infra red thermometers and start checking things out. Radiator, oil coolers, individual exhaust runners etc. Also proper adjustment of transmission control linkage, working gauges, thermostats and water passages. There is a chance that temperature and transmission issues are related so start the sleuth work first.
Mon, Oct 2, 2017 9:09 AM
captainhowdy
Send a private message to captainhowdy
I had a D6D that started to run hot over time and progressively got worse. i had the perfed hood and side enclosed doors that were perfed too. turned out to be a combination of to many paint jobs closing up the perfs and the major culprit was worn out crank and fan pulleys. even though the belts wouldn't squeal it still couldn't pull the fan.
Mon, Oct 2, 2017 9:26 AM
Jfehrle
I'll start checking everything to see if I can find something hot. I think I read that the radiator should be around 20 degrees difference from top to bottom? If the hood is supposed to have vent holes as above that might just be it.
It takes about 1 1/2 to 2 hours of hard running to get it hot.
Mon, Oct 2, 2017 9:40 AM
captainhowdy
Reply to Jfehrle:
[quote="Jfehrle"]I'll start checking everything to see if I can find something hot. I think I read that the radiator should be around 20 degrees difference from top to bottom? If the hood is supposed to have vent holes as above that might just be it.
It takes about 1 1/2 to 2 hours of hard running to get it hot.[/quote]
except for the shifting problem your symptoms sound exactly like my experience. i replaced the radiator in my tractor before i figured out the real problem OUCH. i never allowed my tractor to get to the red but it would have. the pulleys didn't look bad but they were.
Mon, Oct 2, 2017 7:14 PM
seiscat
Reply to captainhowdy:
It's best to try one change at a time to identify the problem. Number 1 is the solid hood. You should be able to find a Caterpillar perforated hood at salvage yards, or Kenco Mfg. of Atoka, OK makes new aftermarket hoods. The solid hood with engine enclosures is a sure cause for overheating.
Worn pulleys are a common problem on the D6D/C. Check the fanbelts on the fan pulley, if the edge of the pulley sticks above the belts the belts and/or the pulleys are worn. If you are not sure about the pulleys, try a new set of belts. The new belts should stick a over a little above the edge of the fan pulley. Run the tractor for a day then re-tighten the belts. If you hear excessive belt squeal, it is a sign of worn pulleys. the new belts should seat-in and be even with edge of the pulley.
Thanks for posting your location. Turns out you are about 140 miles from me.
Craig
Mon, Oct 2, 2017 11:55 PM
seiscat
The air flow and belt slippage problems I described are the only problems that won't be found with a temperature gun.
Old Magnet's advice about using the temp gun to diagnose other cooling system problems is spot on.
Garlic Pete if you find that your radiator core needs cleaning it is a not too difficult of a DIY project. The tanks bolt on to the core and the cooling tubes can be cleaned using a thin metal strip. The D6C/D/E models that don't have an oil cooler beside the radiator core have radiator cores that can be reversed so that a "fresh" side will face the fan if you are having "sand-blast" issues. I use only antifreeze and distilled water in my cooling systems to reduce electrolysis.
I look forward to what you find on your D6C. Pictures would be great if you have time.
Craig
Tue, Oct 3, 2017 10:10 PM
Reply to seiscat:
Craig
I don't agree with that first statement. Lack of air flow and/or pulley slippage will show up as poor heat transfer across the radiator tanks.
Tue, Oct 3, 2017 10:43 PM
seiscat
I stand corrected Old Magnet. I should have stated that it just would not be as obvious as other problems. The lack of airflow because of the solid hood would especially be hard to find.
Craig
Wed, Oct 4, 2017 12:07 AM
