D6D 04X Oil change
D6D 04X Oil change
Kwright
Send a private message to Kwright
Any guidance/procedures on changing the oil and filter from you professionals?
I currently do not have a service manual for the D6D, I do have one for a D6C.
While underneath the dozer there is a hole with 2 slots, is this where the drain plug is located?
Further aft is a access panel with 4 bolts, I’m not sure what that accesses?
Fuel filter replacement guidance/procedures?
Sat, Oct 13, 2018 1:22 AM
buch933
Send a private message to buch933
There should be an access hole in the left side of the belly pan inline with the hole with the 2 notches in the bottom you are referring to. Use a long extension and a 9/16 socket thru the hole in the side to open the "drain valve"
Tom
Sat, Oct 13, 2018 1:42 AM
buch933
Reply to buch933:
Tom
On my D6D 04X the engine oil capacity is 7 or 7.5 gal.
Sat, Oct 13, 2018 4:12 AM
Kwright
Reply to buch933:
Tom
[quote="buch933"]There should be an access hole in the left side of the belly pan inline with the hole with the 2 notches in the bottom you are referring to. Use a long extension and a 9/16 socket thru the hole in the side to open the "drain valve"
Tom[/quote]
Found it, thank you!
Sat, Oct 13, 2018 6:51 AM
