D6C Water in Transimssion, 76A
Showing 1 to 7 of 7 results
Beachyw
Send a private message to Beachyw
Hi All,
It's me again, yet another problem. I've slowing been losing radiator fluid and today noticed that it's in my transission. It's over full and grey. Grey like my hair is rapidly becoming.
My first suspicion is the transmission oil cooler but I put in a new Cat one when I replaced the engine in the fall. Not saying that's not the problem just wonder if there might be a seal or something somewhere that I should check first. I remember replacing some of the trans oil cooler oil line seals at the cooler but can't figure out where else the fluids could mix.
Thanks as always.
Wendell
Mon, Jul 6, 2015 7:43 AM
Was the cooler a "Cat Classic" part or Gen. Cat?
Gary
Mon, Jul 6, 2015 8:13 AM
Beachyw
Gary
It was general Cat
Mon, Jul 6, 2015 8:26 AM
Reply to Beachyw:
It was general Cat
Any sign of oil in the cooling system?
Transmission oil cooler is about the only place transfer could occur.
Normally the oil side of the cooler would be higher pressure than the cooling system
Mon, Jul 6, 2015 11:54 PM
catsilver
The pressure in the transmission cooler is only lube pressure and could be below cooling system pressure when hot, the oil could also be too viscous to go through a hairline crack in the cooler, but coolant will, after the engine is shut down and there is still pressure in the cooling system.
Tue, Jul 7, 2015 12:24 AM
Beachyw
Reply to catsilver:
There is some oil in the radiator. Thanks for the help. Guess I'll get one on order.
Tue, Jul 7, 2015 9:13 AM
Reply to Beachyw:
All signs of oil/water being transferred across the cooler as either side alternates from hot to cold and cycles through the operating temperatures and pressures.
Tue, Jul 7, 2015 9:25 AM
Better make Cat warranty it!!! if you bought it new. Gary
Tue, Jul 7, 2015 10:11 AM
| Hartley - South Australia
