D6C Parts List
D6C Parts List
Xtremist
Send a private message to Xtremist
Hey does anyone have a access to a 69J parts manual for a D6C ?  I need to reseal the hydraulic system and need to find some part numbers...
- gasket for the split hydralic tank
- all external o-rings and gaskets
- gaskets and o-rings for both bell crank shaft supports
- seals and bushings for bellcrank shafts
- bellcrank shafts themselves in case they are worn
- also need to reseal the suction line from the sump to the transmission
Thanks a bunch for the help !
Sun, Jun 12, 2022 2:08 PM
seiscat
To get these part numbers you need to list the serial number of the hydraulic system, it is normally located on the hydraulic tank.
Craig
Mon, Jun 13, 2022 12:10 AM
Xtremist
Reply to seiscat:
Craig
machine is a 69J2622
hydraulic system is a 33H 2356
Mon, Jun 13, 2022 1:56 AM
seiscat
Reply to Xtremist:
Here is the parts book you need.
https://www.ebay.com/itm/393062409168?hash=item5b845863d0:g:bHIAAOSwsWBf3kCe&amdata=enc%3AAQAHAAAA8Eu27%2FiQ57YdX1RCqXOorutyDQt7jSgKMqT2ZCtc8UOhzQClO9mqcIW56%2FvGdjH07iwtwbihv2fZEAjnAeEDqYKRkOV9kJgw3WBIPK9blyLADLLWZuP6lj0sEnCboJqoZAESd6s0WVrQlZSTDNtX0q0mYBrt3Hzk1Q%2FS5Q4OvXuTmhZ0EskLNS691LZS9%2Fu7vg2zlf%2B%2FBRsBaGWaZn0%2B8OvBS9syBCWPgqrJs86RIfuMQd1558hkU1FXYUo3ZbhNLEha2iZO0yfDRdZnqBuqufKEfb5Lnsy7SKN5WbjkZhPP9wFpSFy3Z4ZCRb6jhP6ZTQ%3D%3D%7Ctkp%3ABFBM8ozHlqtg
Mon, Jun 13, 2022 2:37 AM
Xtremist
Reply to seiscat:
I will order that book, in the meantime is there a chance anyone could look up the stuff i need ?  The book wont show up for a couple weeks...
Mon, Jun 13, 2022 8:16 AM
