D6c manual tilts
D6c manual tilts
bcguide
Send a private message to bcguide
Hi all
I have a 6c and the manual tilts are wore out. I was wondering if any of you had a fix for them.
Sun, Mar 16, 2025 4:46 AM
Thank you received: 54
they are a type of turnbuckle so a similarly sized one would work. or cut the threaded ends of and turn up new ons weld em on the the original eyes and adjuster sleeve
Fri, Mar 21, 2025 8:06 AM
bcguide
I guess that is what I am going to have to do.
Was hoping there was a way to modify the turnbuckle to just use the bottom threads.
Mon, Mar 31, 2025 8:55 PM
bcguide
  • I found a set of tilts from a komatsu and adapted them the the 6c
Sat, Aug 9, 2025 12:29 AM
Thank you received: 140
Hi,bcguide.
So now all you need is some 'jen-u-wine' Cat yellow to cover up that awful 'other brand' color? And maybe some work to make it look like those new tilt braces were 'always' there?
Sat, Aug 9, 2025 6:39 AM
