D6C hyd pump shaft seal
Showing 1 to 10 of 11 results
davo727
Send a private message to davo727
Looks like hyp pump is putting oil into the engine. Hope to get a shaft seal on hand before taking it apart. Its a 10k 10839. Powershift turbo.
Thats the only number readable on the main tag.
The tag on front of hyd tank looks like 3903558.
Anyone have a seal part number? Thanks.
Thu, Apr 10, 2025 9:28 AM
davo727
Thu, Apr 10, 2025 9:35 AM
davo727
That's a 39G3558 Hydraulic Control
Shows three different possible hydraulic pumps
9J8771 and 3G4768 uses seal kit #9J0765
8J3635 uses seal kit #6J9828
I'd have to see pictures of the actual pump to tell which one.
Thu, Apr 10, 2025 5:27 PM
davo727
Fri, Apr 11, 2025 2:24 AM
davo727
Fri, Apr 11, 2025 2:25 AM
davo727
Fri, Apr 11, 2025 2:26 AM
davo727
Thanks, do these pics narrow down which kind of pump? Thanks.
Fri, Apr 11, 2025 2:27 AM
Yes, that takes the 9J0765 seal kit.
Fri, Apr 11, 2025 5:07 AM
davo727
Perfect. Thank you sir!
Fri, Apr 11, 2025 5:14 AM
davo727
Is the hyd tank vented? Should I look into it might be plugged?
Fri, Apr 11, 2025 6:07 AM
