D6C Crawler Transmission Locked?
Enigma1008
Send a private message to Enigma1008
Hello, I'm new to the forums. I have a 1975 D6C Caterpillar Dozer with the following information:
MODEL No. D6C
SERIAL No. 47J 4474
ARRANGE No. 3P1777
ENGINE 3306
49V 7370 2P6795
I wasn't operating it when it locked up and I'm not sure my brother-in-law is telling me everything. The engine runs fine and shows 300 PSI at the Transmission Oil Pump. The blade operates normally. I disconnected the Universal Joint and the Torque Converter turns freely but the transmission will not turn at all. I've been told that it shouldn't turn even in neutral but I'm not sure. I bought a Torque Converter ($1,200.00) and was going to change it but now I'm not sure it's the problem.
Where should I start to diagnose the problem? Any help here would be greatly appreciated. I really can't afford to have a mechanic come out into the middle of nowhere to fix it.
Thanks!
Brett
[attachment=51214]D6C Cat.jpg[/attachment]
Thu, Oct 25, 2018 9:32 PM
bursitis
will it roll? have you tried shifting into gear with the steering levers pulled all the way back. have you made sure the park brake is disengaged?
Fri, Oct 26, 2018 3:14 AM
Reply to bursitis:
Check the easy stuff first. Check shift linkage adjustments and or if something is jammed or broken in the linkage. Possible that transmission clutches are not releasing.
Fri, Oct 26, 2018 3:58 AM
Loosen the brake bands once and see what it does.
Fri, Oct 26, 2018 5:29 AM
GMBM
Send a private message to GMBM
The transmission input shaft should turn free in neutral
Most likely you have transmission problems if it was anything behind the trans the input shaft would still turn
Greg
Fri, Oct 26, 2018 6:52 AM
doylex
Send a private message to doylex
Reply to GMBM:
Greg
Correct the input shaft should turn in neutral. Under your left foot is a hinged access check the filter under there. That will explain lots. The planetaries probably dropped out of the carrier and thats that.
Sat, Oct 27, 2018 9:37 AM
