D6C clutch problems
D6C clutch problems
Showing 1 to 10 of 11 results
Boaz63
Send a private message to Boaz63
10K 9564 has developed a problem. It will go in reverse and back up in all three ranges and when shifted to forward will not pull correctly it acts like the clutches are slipping. The strainer has been cleaned and filter replaced. At idel pump pressure is 375. Torque converter temp is normal. This problem started abruptly while backing down hill. 😕😕What are the specs on clutch pressure test?
Wed, May 16, 2018 1:07 AM
Thank you received: 46
Pump pressure should be 315 psi min, 350 +/- 10 psi max
Same pressure for speed clutch.
Direction clutch should be 55 +/- 8 psi less than speed clutch.
Wed, May 16, 2018 2:04 AM
Thank you received: 31
suggest check operators platform mountings, seat mountings etc for tightness and the trans selector linkages for worn lever shafts/bushings in the trans case itself along with the correct adjustment and wear in the rose/ball joints of the rods.
If the platform etc is loose or slightly so it can move with the steep angle change and so alter the trans selector linkage adjustment positions causing what you see.
Personally know of a customers 769 truck that developed a loose platform, it downshifted itself (3rd to 1st) unexpectedly whilst going downhill and blew its engine from over speeding.
Wed, May 16, 2018 7:03 AM
Boaz63
[quote="Old Magnet"]Pump pressure should be 315 psi min, 350 +/- 10 psi max
Direction clutch should be 55 +/- 8 psi less than speed clutch.[/quote]
Thanks Old Magnet for the information. Upon further investigation while preparing to check pressures at the directional control I had the top off of the transmission and started the unit up I noticed it was spraying out oil in the right hand corner of the control valve while still in neautral also noticed oil needed to be changed it looked like black kerosene. This morning I did do a quick check I locked both brakes and was able stall the torque converter in all three ranges forward and reverse. When it comes up to running temperature I can no longer stall the torque converter in all three ranges forward and reverse. I’m going to change the fluid with TO4 30W and new filter and then proceed with pressure test.
Wed, May 16, 2018 11:10 PM
Boaz63
Reply to edb:
[quote="edb"]Hi Team,
Eddie B.[/quote]
Thanks Eddie B we have checked all the linkages, ball joints and adjustments appear to be ok.
Wed, May 16, 2018 11:12 PM
Reply to Boaz63:
Seems there is a problem with leakage on the #1 (forward) clutch.
Thu, May 17, 2018 1:08 AM
Boaz63
25 gal of Cat TO4 30w fluid cured the old Girls ailments. One more reason to use Cat spec parts
Thanks Old Magnet & Edb
Sat, May 19, 2018 6:44 PM
Reply to Boaz63:
Sounds to easy. LOL. Did you run the pressure checks?
Sat, May 19, 2018 11:11 PM
Boaz63
315-360 speed control
260-300 directional control
Pressure test was performed after 1 hr of operation, Torque convo temp midway in normal range
Sun, May 20, 2018 7:15 PM
Reply to Boaz63:
Hi Boaz63,
thanks for returning to give us your findings and test results--helps others in future with similar problems--if only they could all be so easy to remedy.
Sun, May 27, 2018 7:04 AM
Richard~J~W
Send a private message to Richard~J~W
Reply to edb:
Hi Boaz63,
sorry for squeezing in to this thread, but is it the same test procedure for a D6D?.....if so is the only test port needed located in the filter head on the engine?
Mon, May 28, 2018 3:59 AM
