D6C Bottom Roller Help Please
Ricky
Send a private message to Ricky
replacing bottom rollers on D6C, book calls for 3 single flange and 3 double flange rollers. the current set up is not the same left side to right side, not sure which is correct.
so starting from the final drive sprocket, do I start out with a single or double?  this way? sprocket - sf, df, sf, df, sf, df - idler, or this way? sprocket - df, sf, df, sf, df, sf, - idler, any guidance would be appreciated, Thank You, Ricky
Wed, May 8, 2024 8:04 AM
This should cover it.....
 [attachment=76325]Roller Sequence.jpg[/attachment]
Wed, May 8, 2024 8:10 AM
Mschwartz
OM, could you please elaborate on the diagram you posted? Looking at the 6 roller diagrams why are there two different options? I have noticed on my ag D5 and d6 cats they are not all the same either. Seems like I find more double flange rollers, maybe because of the hillside farming? Just curious and wanting to learn more, thanks, Mike
Wed, May 8, 2024 10:27 AM
Reply to Mschwartz:
As you suspect, more double flange units for hillside work. The down side is they tend to trap and channel more debris.
Wed, May 8, 2024 12:03 PM
Thank you received: 55
so what's with the arrows is that "wheel rotation" order ie to even out the wear?
Wed, May 8, 2024 8:19 PM
