D6C 76A fuel issue?
D6C 76A fuel issue?
mustang
Send a private message to mustang
Hey folks, I'm working on a D6C that belongs to my Dad. It's a 64' model 76A. The problem is the last time we crank her up, the engine sped up ok, then wouldn't turn up more than idle. I'm just a shade tree mechanic and by no means a diesel tech. I'm changing fuel filters, both primary and secondary. The primary filter had a good bit of crud in the cup. I have a service manual. I'd like to know if there is anything I can look for that might explain a possible fuel problem. Is there a way I can check to see if the rack is moving properly. Picking up new filters in the morning. Any help would be greatly appreciated!
Thanks,
Kenneth
Fri, Sep 20, 2013 6:50 AM
What's the oil pressure like? That D333 engine has a rack limiter piston in the governor that will not let the engine speed up until the oil pressure comes up.
Also possible that the lines between the tank and the lift pump are clogged or loose in the ferrules and letting it suck air. Had a lot of trouble with our grader from about that time. The lines were just not sealing up tight any more. Didn't leak a lot of fuel, but was awful to prime it up and it would loose prime anytime it sat.
Fri, Sep 20, 2013 9:20 AM
mustang
Thanks ccjersey for the reply. I don't know what the oil pressure reading was the last time it ran. Will be putting the new filters in tomorrow. With the amount of crud I found in the primary filter cup, I wouldn't be surprised that the line is choked up. I had taken the fuel filter housing, fuel transfer pump off engine and cleaned everything up. Will be looking at oil pressure if I get it cranked. Also planning on draining all fuel out of tank, blowing out fuel lines, and refiling with fresh fuel.
Thanks again for the help!
Kenneth
Fri, Sep 20, 2013 10:17 AM
rusted
Send a private message to rusted
Reply to mustang:
Kenneth
[quote="mustang"]Thanks ccjersey for the reply. I don't know what the oil pressure reading was the last time it ran. Will be putting the new filters in tomorrow. With the amount of crud I found in the primary filter cup, I wouldn't be surprised that the line is choked up. I had taken the fuel filter housing, fuel transfer pump off engine and cleaned everything up. Will be looking at oil pressure if I get it cranked. Also planning on draining all fuel out of tank, blowing out fuel lines, and refiling with fresh fuel.
Kenneth[/quote]
What's the fuel pressure reading?
Fri, Sep 20, 2013 1:25 PM
Reply to rusted:
Kenneth[/quote]
it is not unknown for the limiter mentioned to not retract, even when the oil pressure has come up, due to the components being worn in there and a lot of pressure has been applied to the retraction plunger by heaving the gov. control lever to the run position hard against the plunger.
Usually if you can get the engine to start, back the gov. lever off a tad, and then open it up to required gov. setting. This eases the load on the plunger and it will usually retract.
On reco'ed engines we used to pre lube the engines with a pressure pot filled with engine oil and connected to the engine oil system somewhere convenient. This would get the piston retracted to get to full open gov. setting to bleed the fuel injection system.
From memory, another place that can foul things up is in the canister of the de-accelerating mechanism.
If the canister fills with dust/mud it cannot extend/retract.
Also check for seizures in the bushings of the bellcrank lever and the cross shaft in/on the bracket that holds the gov. control crossover linkages, that has the circular housing with the brake detent for the gov. linkage holding device.
Sat, Sep 21, 2013 8:19 AM
mustang
Reply to edb:
Hi rusted, don't know yet what the fuel pressure is yet. Got the fuel transfer pump and fuel filter housing re-installed today. New fuel filter, primary filter, gaskets. The fuel tank was about 60% full. Not taking a chance on bad fuel, so I drained all old fuel out. Took primary fuel line off of the shut off valve, attached a hose to the fitting, drained fuel into barrel. I took an old inner tube, cut the valve section out of it, fastened it to the fuel tank fill opening with a hose clamp, pressurized it a little. Really sped draining the tank. Next, going to flush tank out best I can. Put some good fuel in it. Use the pressure trick to help bleed system, and hopefully she will fire up. EDB, Thanks for the info on the rack limiter stop. I will pay special attention to this. I had the governor cover off the injection pump, cleaned the plunger assembly and put it back on.
Thanks again all,
Kenneth
Sat, Sep 21, 2013 11:37 AM
| Hartley - South Australia
