D6c 76a 1414
D6c 76a 1414
Showing 1 to 9 of 9 results
VopataR
Send a private message to VopataR
I’m looking to buy this machine. Can you tell me pros and cons comparing this machine to a 10k machine?
I think the steering clutches and brakes run in oil. Is this correct?
Fri, Nov 23, 2018 9:29 AM
Thank you received: 39
Steering clutches and brakes are oil type.
Engines went from D333A in the 76A units to D333c in early 10K then 3306 engines in later 10K's.
Fri, Nov 23, 2018 2:06 PM
VopataR
How does the 333a compare to the 333c or the 3306 for that matter this machine has 80% undercarriage and all the pins on the blade are tight new batteries and seems to run out fine. I think I will go to around 15k on it does that sound reasonable?
Fri, Nov 23, 2018 9:13 PM
Casey Root
Reply to VopataR:
Does it have a ripper or winch? How about a ROPS? Is the machine strait without a bunch of bent panels? Is the undercarriage SALT?
If it doesn't have a winch or a ripper and is as you have described, then for west coast pricing it is about right.
Be sure the cooling system is top notch. The power shift units had some heating issues under steady heavy use which leads to a plethora of engine problems. The 74As engines gave very good service as they didn't have the task of trying to cool the torque converter along with the engine. Especially in draw-bar applications.
It is a 120 HP unit and the switch to the 10K bumped the HP to 140 and stayed at that rating all the way through the production run. I think it was 140HP in the D6D also, but I'm not positive.
They are a good durable machine as they are still viable units even being 50+ years old.
Enjoy 76A 1414.
Fri, Nov 23, 2018 10:41 PM
smocat35
Send a private message to smocat35
Reply to VopataR:
My dad owned 3, maybe 4 D6C dozers around 1968 thru the 1970s, then a couple of 10Ks. The 6C dozer was my first experience and learning machine and which I have spent many hours on. I remember one of the s/n being pretty close to your #. I don't know the difference between the A & C engines or what dads dozers had in them,they were all bought used and probably I have ran both and didn't know it. I don't recall any memories of earlier dozers being any more problematic than later ones. They were a very reliable dozer and we put a lot of hours on all of them and rebuilt a lot of components due to hours of use, not from any what I would call as design weaknesses. With the undercarriage being as tall as you have mentioned and if the machine operates and performs comparable, 15K sounds reasonable, but I could see a really good example earning a few K more.
Fri, Nov 23, 2018 10:55 PM
Reply to smocat35:
The D333A is a 4-1/2" bore engine. They were subject to cracking heads and spun bearings and went through many evolution items over the coarse of production. The D333C is a 4-3/4" bore engine, much improved over the D333A and the for runner to the 3306 (4-3/4" bore) engine and considered the best of the series.
Sat, Nov 24, 2018 1:59 AM
VopataR
Thanks to all for the replies no winch no ripper just drawbar it does have a factory tops pretty straight machine but it could use paint thanks again
Sat, Nov 24, 2018 2:27 AM
Kwright
Send a private message to Kwright
[quote="VopataR"]I’m looking to buy this machine. Can you tell me pros and cons comparing this machine to a 10k machine?
I think the steering clutches and brakes run in oil. Is this correct?[/quote]
I’ve owned a D6C with a 3306 and I currently own a D6D also with a 3306 engine.
The 3306 is held in high regards among Cat owners. I believe in the long run your investment in a 3306 powered D6C is better protected and a will offer better resale value.
When I was initially looking to buy a D6C I was advised to buy one with a 3306 engine, and when I decided to sell my machine almost all the potential buyers asked if it had the 3306.
Sat, Nov 24, 2018 10:10 AM
Kwright
Sat, Nov 24, 2018 10:18 AM
Silver
Send a private message to Silver
Reply to Kwright:
I've had my 76a to 15 years. It's done a bit of work over that time. Cleared fence lines, dug water holes, cleaned corrals, cleared about 60 acres of forest and turned to hay land. All I've ever done is repair worn out things on it. They are a little under powered, but they get the job done.
Sat, Nov 24, 2018 11:12 AM
