D6c
Showing 1 to 7 of 7 results
stuartmarshall
Send a private message to stuartmarshall
Hi all thought I’d share some pics of my dozer . D6c 56j Australian built. No turbo. I’ve just given it a pretty complete inframe, and redid the brakes as it bounced the brake band on one side. It was parked 10 years ago with the brake problem and a broken valve. Went underwater in a flood about 4 years ago.
Currently down with a blown track tensioner seal and it’s putting oil in coolant so about to pull and check the heat exchangers.
Mon, Feb 11, 2019 1:59 PM
stuartmarshall
Yes starter needs attention too. And a bunch of other things!
Mon, Feb 11, 2019 2:04 PM
rustyfender
Send a private message to rustyfender
Reply to stuartmarshall:
Good old yellow fever, nice to see pictures
Tue, Feb 12, 2019 6:24 AM
Rd6 plower
Send a private message to Rd6 plower
Reply to rustyfender:
Nice Cat that’s Aussie 10K pretty much should be 120hp non turboed 140 turboed
Far as your water in oil don’t forget the water pump is gear drive and can get in thru there also usually before cooler springs a leak
Tue, Feb 12, 2019 1:49 PM
Rd6 plower
Reply to Rd6 plower:
Sorry I misread your statement oil getting in radiator sounds like cooler
Tue, Feb 12, 2019 1:52 PM
Wombat
Donor
[quote="Rd6 plower"]Nice Cat that’s Aussie 10K pretty much should be 120hp non turboed 140 turboed
Far as your water in oil don’t forget the water pump is gear drive and can get in thru there also usually before cooler springs a leak[/quote]
The 56J series tractors were 125hp naturally aspirated 3306, the next series the 69J started at 125hp and finished up at 140hp. The 56J replaced the 73A series.
Wombat
Tue, Feb 12, 2019 2:11 PM
stuartmarshall
Reply to Wombat:
Wombat
its actually a d333c, early 56j #274. Its a pain as i have a service manual for a d6c which includes 56j, but covers specifics of 3306s and the new sleeve fuel systems.
Hopefully its just a faulty cooler. Easy to diagnose and fix.
Tue, Feb 12, 2019 3:01 PM
stuartmarshall
Easy but potentially expensive, id rather spend a couple hundred dollars on a cooler then spend days mucking around to find a bad o ring or something!
Tue, Feb 12, 2019 3:04 PM
