D6B radiator drain cock stuck
Hdonly
Send a private message to Hdonly
Wanting to flush out the cooling system as much as possible. I found the drain cock on the lower elbow is stuck. I am guessing it turns clockwise to open? I have tried both ways but don't want break anything. I am using a six point socket. Would it be safe to bump it with an impact wrench?
Fri, Jan 25, 2019 9:15 PM
nomorejohndeere
Send a private message to nomorejohndeere
I would think clockwise to close
righty tightie
Fri, Jan 25, 2019 10:39 PM
Reply to nomorejohndeere:
righty tightie
Counter clockwise to open.
Fri, Jan 25, 2019 10:42 PM
Hdonly
That is the direction I started with, but nothing moved. I wanted to double check so I don't destroy something. I have put as much pressure on it with a 1/2" ratchet as I dare. Thinking maybe just bump it with an impact.
Fri, Jan 25, 2019 11:32 PM
I would try heating the pipe casting around the valve screw threads
The one on my D6 9u was really stuck tight too
Sat, Jan 26, 2019 9:16 AM
| Kingaroy, Queensland
